I thought I would provide some input here. I have had these coilovers in forever and decided it was time to get every mm of travel possible.
Since this is useless without documentation... here goes
Coil bucket cut and CO mounted back in
Spindle gussets welded up... I'm finally getting to be pretty consistent
All done and welded up!
The foam board is dimensioned and cut based on the CAD file dimensions, the final product will have internal gusseting, distributing the load all throughout the top of the coil bucket. Two 1.5" DOM tubes will come up from the frame to brace the coil bucket laterally.
Last, but not least I'll finally be using the limit straps that I've had for a few years
Tabs and plates I will plasma cut out, and I am trying to find the best place to add tabs to the LCA for the straps. Time will tell!
