Originally Posted by Illicitdream
I get P0340 after changing my TB recently and it wont go away. I wont be able to work on it for a couple days, but it is my daily driver. Can I drive safely with this cam position sensor being faulty or bad without doing any damage to the engine? I didn't know exactly what the sensor would do other than give information to the ECM about where it thinks the timing is for the cams... Any thoughts?
It shouldn't be a problem. If you don't have a 0330 or a 0325 code for the knock sensors then the ECU should be advancing and retarding timing as needed so you don't have any pre/post-ignition. The ECU uses the crank sensor for ACTUAL crankshaft position and speed. I extracted the code and wiring schematic info from the FSM for you. This is an indication sensor only and doesn't control anything. Like
Brveagle
said the ECU will revert back to it's default values. Hope this helps.
Disclaimer: I'm not a Toyota Technician. You make the call.
2001 Imperial Jade Gold Letter Sport Package - Original Owner
