05-17-2015, 04:36 PM
#16
Banned
Banned
Originally Posted by azcat90
Yes. Mitsubishi belt with Aisin kit.
I thought so. I just put the same thing on mine. The marks will make it easy to be sure everything is lined up properly.
05-17-2015, 05:46 PM
#17
Also use an OEM t-stat (#90916-03075), not the Gates in the picture:
OEM vs. Aftermarket surprise. Thermostat
05-17-2015, 07:52 PM
#18
Originally Posted by LittleCaesar
Thanks! If I'm going to bury a part that deep it better work - I'll pick up a Toyota part.
2000 4Runner Limited V6
1997 4Runner Limited V6
05-20-2015, 04:19 PM
#19
Crank timing pulley view - yeah I chipped part of it off with a screwdriver
So the crank was/is off a couple teeth and as i was trying to pull off the crank timing pulley to change the crank seal, I chipped part of it off with my screwdriver.
So...
A. Do I now need to replace the crank pulley?
B. How do i get it off to replace the seal?
05-20-2015, 04:42 PM
#20
Yes, the little teeth is what is read by the crank sensor. Costs about $60. Dealer only item.
Lots of PB blaster, then take a small hammer (think 5oz rock hammer) and hit it on all sides. Taking the key way out of the crank would probably help, so soak it as well.
05-20-2015, 05:32 PM
#21
...Taking the key way out of the crank would probably help, so soak it as well...
Thanks - what do you mean by taking the key way out?
05-20-2015, 05:58 PM
#22
Metal thing on crank sticking out and up a little on the left. That's the keyway.
Picture looks like it's pretty rusted, been leaking for a while. Make sure you clean it up good when you put it back together, I typically use emory cloth.
2015 T4R TRD Pro in super white, Morimoto 4300K HID kit, Auer Engineering / Toyota LED DRL/Fogs 2-in-1's, TRD drop in air filter, WeatherTech front and back liners.
2002 T4R SR5 4WD Onyx Black Sport Edition w/Leather. Gone but not forgotten.
05-20-2015, 06:40 PM
#23
Crank was 2 teeth from TDC
So my original question - the last pic shows that the engine was running with the crankshaft 2 teeth off of top dead center when both cams are at top dead center - is that possible?
05-20-2015, 06:48 PM
#24
You sure the cams were at TDC as well? 1 Tooth would make it run really rough, I don't know about 2 teeth. You know if you are one tooth off just by starting it after putting new belt on.
05-20-2015, 06:50 PM
#25
Real Name: Bob/Buckwheat
Yes, replace the oil cooler hoses down by the filter. If that fails you are walking. And they live a hard life as they are right next to the exhaust manifold.
And pull the plugs. Makes it much easier to turn the crank and align the timing marks.
"I speak three languages and liberal ain't one of them."
05-20-2015, 07:29 PM
#26
Yes it can. At 285k I can believe it. Line up the marks correctly, pull the tensioner pin, then rotate the engine to make sure the marks line up as they are supposed to.
If the engine is that far out of sequence, don't be surprised if you hear some different sounds. Checking the valve clearance may be necessary sooner than later, maybe not.
05-21-2015, 09:58 AM
#27
Crank seal
OK thanks again guys (I assume you're all guys - call me sexist) for all the info.
Napa guy said I should replace the oil pump? gasket when I replace the crank seal and then sold me an oil pan gasket since I would have to have the oil pan off to get to it.
So I got under it with my 10 mm socket and then quickly realized that I am a sucker and/or the Napa guy is short on 5VZFE 4WD know-how.
So can I get away with pulling the crank timing pulley off and replacing the crank seal from there? Is it accessible from there?
I'm searching for threads.
05-21-2015, 10:09 AM
#28
That's how you replace the crank oil seal. Honestly, I would only use a Toyota OEM part for that. It would suck to redo all your work, or get oil on the belt.
I had a recent experience with NAPA, don't get me wrong I like NAPA a lot. I had to replace my AC idler pulley. I went to NAPA, and they sold me one that made a lot of noise just by spinning it on my finger. I went back, and they showed me 3 different parts for the same part #! Never opened, all were a little different from diameter size to internal diameter size that you put the bolt through. The owner was perplexed when I showed him the difference between all 3.
For something this critical that you want to last, go with OEM only. Just my .02
05-21-2015, 10:22 AM
#29
How - from under the pulley or do I need to remove the oil pan?
05-21-2015, 10:49 AM
#30
Remove crank timing pulley, the crank oil seal is behind it.
