Old 05-23-2015, 01:10 AM #1
arki01 arki01 is offline
arki01 is on a distinguished road
A/T oil temp warning light and battery warning light concern
Hi guys. I was driving a long drive then suddenly engine stops and A/T oil temp and battery warning light turns on, and when tried to start engine, starter makes a sound but, engine won't start. Timing belt is ok, battery is good, A/T oil is at correct level as well as engine oil. Any similar situation and what did you do?
By the way, it's a 1997 4Runner.
Thank you.
arki01 is offline   Reply With QuoteReply With Quote
Old 05-23-2015, 01:27 PM #2
lhsoulrebel's Avatar
lhsoulrebel lhsoulrebel is offline
lhsoulrebel is on a distinguished road
Thank you.
What did the manual say about it?
Black 99 highlander. toytec ultimate lift with bilstiens, and diff drop. 255 85 BFG KM2's, and tundra 231mm brake mod to stop them. ISR, and deckplate mod, rear diff breather. Front ARB locker and compressor. Scan gauge 2. Yakima mega warrior. Savage rear with swing out. AND NOW....SC'D!!
lhsoulrebel is offline   Reply With QuoteReply With Quote
Old 05-23-2015, 02:30 PM #3
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
Im assuming the A/T light and batt light just came on because the engine stopped and are not a sign of something wrong.
Start with the basics air/fuel/spark. engine cranking so battery has power, maybe fuel pump died? gotta be fuel or spark.
Any engine codes? does it sound normal when cranking over?
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 05-23-2015, 10:45 PM #4
No engine code as only a/t oil temp and battery warning light was on. Cranking sounds seems like it's the starter only that's making a sound. Car was running then suddenly, engine stops.
VSC warning light bimrunner 5th gen T4Rs 35 11-10-2014 10:24 PM
Warning light help JAD 5th gen T4Rs 13 04-29-2014 08:52 AM
A/T Temp Oil Warning Light jmm3807 4th Gen T4Rs 15 06-17-2013 05:21 PM
A/T Oil Temp Light accompanied by Battery light YotaDriver19 Classic T4Rs 5 09-28-2011 10:44 AM
Battery and Parking Break Warning Light Comming On elcidsurfer Classic T4Rs 9 12-12-2010 11:38 PM
