05-27-2015, 02:11 PM
Blown Engine, Worth putting in a new one?
I have a 2002 4 Runner with the v6. Apparently I have damaged the engine beyond repair and it has a hole in the engine block.
Is it worth putting a used engine or new one in the car, or should I say goodbye to my old friend?
05-27-2015, 02:19 PM
Real Name: Woody
Real Name: Woody
Nah you should just give me the truck so I can uh....dispose of it for you. Jk...
I would try to find a low milage original replacement engine....unless you damaged a bunch of other things too. All just depends on the condition of everything else.
05-27-2015, 02:42 PM
Real Name: Chris
Real Name: Chris
Our vehicles are old enough that if you absolutely had to a reman block isn't that bad price wise but like stated above the engines seem easy enough to source used. They are always on my local CL for sale.
I guess it really depends on how much you love your vehicle.
AzBub Build2000 Toyota 4Runner Highlander, 4x4, E Locker. 4:30 gears. TRD Taco springs on Tundra 5100s. FJ80 8 wraps/Monroe economy rear lift.
05-27-2015, 05:28 PM
I found a junk yard that has and will put in an 110K engine for $1950. What do people think?
05-27-2015, 05:34 PM
Real Name: Alex
Real Name: Alex
They'll pull your engine and install a new one for $1950 including price of the engine?
If you're not mechanically inclined, I think that sounds like a pretty good deal... Some rebuilt 5vz's on my local craigslist are like $1800...
Keep in mind, a junk yard is a junk yard and a "mechanic" that works at a junk yard works at a junk yard...
Can get your engine pulled, "new" one installed, and a 5 year 60k mile warranty for $3200.
2006 Lexus GX 470 Sport- RR Diff Lock, Metal Tech Sliders, RCI Aluminum Skids, Front Runner Slimline II Rack, SCS F5s, 255/80R17 ST Maxx , OME BP-51s, Dirt King UCAs, Metal Tech RR Lower Links
2016 Lexus IS300 F Sport- F-Sport Air Filter RR Racing tuner
05-27-2015, 05:45 PM
JDM Engine Depot in NJ has them for $899, with between 45-60k miles.
http://www.jdmenginedepot.com/jdm_en...gine-jdm-5vzfe
I think you can find someone to put it in for $500-600.
2001 Toyota 4Runner SR5 Sport
Imperial Jade Mica
231mm Tundra Brakes
5100 Bilstein / TRD / OME 890 3" Lift
285/75/16 BFG KO2s
05-27-2015, 05:59 PM
How many miles on the truck? It would suck to spend that coin on a rig with 300k to have something fail afterwards. In my neck of the woods, a used v6 is available for way less, if you install. That'd be the route I'd take. 2cents. Good luck.
05-27-2015, 06:11 PM
Real Name: Bob/Buckwheat
I see you are from New York so the first question to ask is how bad is the frame and/or body rusted out?
I have seen a lot of east cost vehicles that are just beat to hell.
If the frame and body are in good shape and you like the truck, I'd go for it.
Just remember a used engine is always a crap shoot. A re-manufactured engine is always the safe bet and almost always have at least a 6 month warranty.
"I speak three languages and liberal ain't one of them."
05-27-2015, 08:41 PM
Depends.
What will you drive if you don't replace it?
If you have spent a lot on mods and upgrades or care it could be worth it.m
If you plan on getting another one can you find one that is better for less $$$ and in good shape?
I probably would as the other posters have said, if the rest is in good shape I would.
05-27-2015, 11:07 PM
Originally Posted by Supermoney
I did this. Over last winter. Not bad at all
Betty:97 SR5 succumbed to frame rot
Eileen:98 SR5 in progress...
Facebook:
NJ 4runner Association
Northeast 4runner Owners Association
05-28-2015, 01:28 AM
This has been covered many times over the years, but just to reiterate it here: JDM engines are a crap-shoot.
The claimed mileage may or may not be accurate, and the condition of the engine is always a mystery.
Japanese people are just like people anywhere: Some maintain their vehicles, and some completely neglect them.
You might get a great engine, or a piece of junk.
I would recommend pulling the valve covers, oil pan, and spark plugs, on any prospective engine you are thinking of buying, so you can at least give a cursory inspection prior to buying.
20+ years ago when I was working on consumer cars regularly, the magic engine mileage number the JDM importers claimed, was 30k miles.
05-28-2015, 02:57 AM
Real Name: Jordan
Real Name: Jordan
My buddy put a rod threw his 3.4 last week. We bought a motor for $550 from a junkyard, and pulled his motor that evening. The next day, he was up and running with his new motor. Easy as pie.
05-28-2015, 09:37 AM
Meh I would be more anal if it was a 2JZGTE or a 4G63 from them, but a simple NA 5VZ....nothing can really go wrong in 60k miles on these engines, they are pretty reliable. And if you have any issue they will give you a new motor (within their warranty time frame). Happened to my buddies K20.
Imperial Jade Mica
231mm Tundra Brakes
285/75/16 BFG KO2s
05-28-2015, 09:50 AM
Check CL. Here they sell you a completely rebuilt 5VZ for $2250 and for another $600 will install it and give you a 1 year warranty. I am sure you could find something similar in your location. For that kind of money I would do it just because I love these trucks. That and I could slap the TRD S/C on it.
2006 SR5 V8
2001 SR5 4x4 Sport (sold)
1993 MR2 5SFE
2012 Rav4 4WD 2GR-FE
