Old 06-11-2015, 08:51 PM #1
ToyNutt's Avatar
ToyNutt ToyNutt is offline
ToyNutt is an unknown quantity at this point
ToyNutt's Avatar
Question Wheel Bearing Replacement
One of my wheel bearings is going bad and I need to replace it. Just turned 200,000 miles and still on the original bearings. Planned on doing it myself but then I read somewhere how difficult it is on 3rd gen's. I think they said they aren't like old school bearings and the axle has to be partially removed. Looking to know if that is true and if I should do it myself or take it to a shop.
ToyNutt is offline   Reply With QuoteReply With Quote
Old 06-11-2015, 08:53 PM #2
s20004runner s20004runner is offline
Real Name: Alex
s20004runner is an unknown quantity at this point
Real Name: Alex
google search "3rd gen 4runner [insert search topic]"
front wheel bearings
Front Wheel Bearings
s20004runner is offline   Reply With QuoteReply With Quote
Old 06-11-2015, 09:36 PM #3
mountain mike's Avatar
mountain mike mountain mike is offline
mountain mike is on a distinguished road
Front or rear?
2001 Black Sport Package
mountain mike is offline   Reply With QuoteReply With Quote
Old 06-11-2015, 09:43 PM #4
ToyNutt's Avatar
ToyNutt's Avatar
Front
Old 06-11-2015, 10:17 PM #5
stir_fry_boy's Avatar
stir_fry_boy stir_fry_boy is offline
stir_fry_boy is an unknown quantity at this point
Super easy. The CV axle has to be 3/4 undone to do it, so consider replacing original CV axles at same time. I replaced both my front axles in about 60 minutes.
Honestly, Toyota bearings are super stout. I wouldnt change them unless they were bad. Most aftermarket bearings are crap compared to Toyota bearings and OEM are very pricey. I have almost 200k on mine, no plans on changing them and I'm anal about my maintenance.
If you want to change them, change the whole assembly, not just the bearing. If you don't, you will need a huge press and it's not worth the trouble.
2015 T4R TRD Pro in super white, Morimoto 4300K HID kit, Auer Engineering / Toyota LED DRL/Fogs 2-in-1's, TRD drop in air filter, WeatherTech front and back liners.
2002 T4R SR5 4WD Onyx Black Sport Edition w/Leather. Gone but not forgotten.
stir_fry_boy is offline   Reply With QuoteReply With Quote
Old 06-11-2015, 11:48 PM #6
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
Also check this.
Toyota 4Runner 4WD 1996 2002 Front Wheel Hub Bearing Seal Kit Assembly OEM Koyo | eBay
It's oem bearing just not oem seals. I bought the kid without the hubs. And replaced both sides
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 06-12-2015, 12:28 AM #7
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough JayRolla will become famous soon enough
JayRolla's Avatar
They are very stout. Both my front bearing seals are pretty shot. Lots of mudding and still kicking fine.
To the OP what makes you think front wheel bearings are failing?
JayRolla is offline   Reply With QuoteReply With Quote
Old 06-16-2015, 04:48 PM #8
ToyNutt's Avatar
ToyNutt's Avatar
Thanks for the help guys. If I decide to do the job myself what else do I need besides the bearings and CV axles?
Old 06-16-2015, 04:52 PM #9
I replaced mine a little over a year ago. I ordered OEM ones from Camelback Toyota and then took off the spindle. Took the spindles down to a machine shop and had them press out the old bearing and press in the new one. I also want to say there are two seals. I replaced the cheap ones and reused the more expensive ones...I think...
Old 06-16-2015, 05:44 PM #10
LBJ if you want.
Old 06-16-2015, 10:11 PM #11
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
I'm in the middle of this right now. I bought my parts from Camelback. I got all new parts. You will need the follow:
1: 2- 90369-54001 Bearings about $65 ea
2: 2- 90316-69001 Outer Seal D type $35 ea (have to be somewhat careful removing
them if you want to reuse them)
3: 2- 90312-95001 Inner Seals V type $15 ea (once again be careful removing them
4: 2- 90521-99114 Snap Ring $5 ea (you will need these as they can get
messed up when pressing the
bearing out)
You will definitely need an HD press. I used a 20 ton press and I thought I was going to break something. I haven't put it all back together yet as I had a setback, but I'm pretty sure it will go together easier than it came apart.
Oh and as Stir fry said this is an excellent time to replace the LBJs $86 OEM Don't use anything else.
Oh and now would be a good time to do the TBU
Oh Also since you have it apart do the LCA bushings
Yep it really never stops.....
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 06-16-2015, 11:12 PM #12
If it was me replacing the wheel bearings, I'd find the whole assembly used via car-part.com and throw it in. Toyota wheel bearings are extremely stout and rarely go bad. It will save tons of time and headache.
Then do new CV axles, and OEM LBJ.
Old 06-17-2015, 06:02 PM #13
Nelsonmd's Avatar
Nelsonmd Nelsonmd is offline
Nelsonmd is on a distinguished road
Nelsonmd's Avatar
Do this if you aren't pretty experienced and mechanically inclined, but you want to save money. Also, you might consider printing out the FSM pages on this replacement so that the shop has the proper order of operations. If you take the part off and take it in, I don't think it should be too too expensive. Alot of the time for a shop is in jacking it up and pulling the parts off.
2000 SR5 3.4L V6 Automatic 4x4, e-locker, 175k Miles, Rust
Imp. Jade Mica with Oak Leather Interior, Field Monitor Unit - B&M Tranny Cooler - SG2 - New (to me) rear axle assembly - Goodyear Duratrac 265/75-16 - 1.8" Ironman Front Lift, OME 906/Procomp 9000 Shocks
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Nelsonmd is offline   Reply With QuoteReply With Quote
Old 06-20-2015, 03:46 PM #14
GVL's Avatar
GVL GVL is offline
GVL is on a distinguished road
GVL GVL is offline
GVL's Avatar
Originally Posted by kolelt View Post
Also check this.
Thanks kolelt; I just posted recently about a possible bad bearing so I just ordered this as well for the front passenger side. I watched a video changing it out on a gen 4 and it looked pretty easy, but I have limited tools up here so debating just taking it to a local guy to have it done.
2000 Highlander - 3" OME 883F 890R - ARB F&R Lockers - AOR Bumper - Savage Armor - WARN M8000 - RIGID LED Floods - TRD Wheels - TBU - HID - BFG KM2
GVL is offline   Reply With QuoteReply With Quote
Old 07-07-2016, 12:08 PM #15
SpidermanGeek's Avatar
SpidermanGeek SpidermanGeek is offline
SpidermanGeek is on a distinguished road
bearing out)
I'm just putting together an idea of how much it would cost to replace front bearings on mine.
Is that list of parts all what would need to be replaced, and whatever was left out can be reused?
example:
43524-35010 Inner bearing Spacer
43515-35010 ABS ring
And then axle nut and such can be reused?
All I should be getting is the bearings and seals?
1997 4Runner Limited V6 Auto 4x4 w/E-Locker - 184K Miles
OME 881/890 Springs, Tokico TrekMaster GU3535/GE3536 Shocks, 1" Front Diff. Drop, Front Frame Mounted D-Rings
All-Pro 1.25" Hubcentric Wheel Spacers, 265/75R16 ETS Trail Master M/T, B&M 70268 Cooler (bypassed)
2010 Matrix XRS 2.4L 5-Speed - 130K Miles
SpidermanGeek is offline   Reply With QuoteReply With Quote
Wheel bearing assembly replacement help nysimonsez 4th Gen T4Rs 27 09-24-2014 12:26 AM
4th Gen 2wd front wheel bearing replacement phil123 4th Gen T4Rs 12 12-24-2013 10:10 AM
Front Wheel Bearing Replacement gstai 3rd gen T4Rs 8 11-18-2012 04:34 AM
front wheel bearing replacement Forrrrest 3rd gen T4Rs 2 11-03-2012 06:38 PM
