Old 06-13-2015, 02:04 PM #1
luther91 luther91 is offline
Real Name: Matthew
luther91 is on a distinguished road
Real Name: Matthew
Trans in limp mode '92 T4R
So when I got the truck it had a knock and needed a motor. Long story short, it now has a 5vz with a 2g SC on it. Before the swap (bad engine) it drove odd and didn't really shift at all, but I wasn't sure if it was due to the power issue. Now after getting the swap in and running on the road, I realize it will not leave second gear, regardless of shifter position (D,2 or L).
I have been searching for something and cannot find much help for my problem. I would assume it is a solenoid or other electrical issue but I cannot be sure. One thing to take into consideration is that I am currently running the 3rd gen trans and position switch with the 4th gen ecu and the ors swap harness.
Since it ran funny before I am not sure the swap is giving me a problem.
Thanks in advance for any advice! I'm glad to be here!
Matthew
luther91 is offline   Reply With QuoteReply With Quote
Old 06-15-2015, 04:37 PM #2
Real Name: Matthew
Real Name: Matthew
bump. any input on checking solenoid function out? I need to open it up anyway to service it.
Old 06-15-2015, 07:14 PM #3
Real Name: Matthew
Real Name: Matthew
update
I put a code reader on it this afternoon and found some helpful starting points. Codes are as follows:
P0115 coolant temp sensor circuit malfunction
P0120 TPS/Pedal position sensor A circuit malfunction
P0505 Idle control system malfunction
P0753 shift solenoid A circuit electrical
P1300 ??
P0135 o2 heater
P0141 o2 heater
P1700 ??
Most of these are not of too much concern right now, but I would like some input on the shift solenoid code. And I think all the engine related ones are from a ground issue (I painted a lot of the engine and messed up by not cleaning paint off in some areas)
Anyway, thanks for any help and I hope some one has some insight.
2014 4Runner w/ 1900mi, Check Engine + TRAC Off, Limp Mode apenso 5th gen T4Rs 36 08-16-2018 10:36 AM
Switching from shift mode to drive mode Happy 1 5th gen T4Rs 31 05-12-2017 12:34 PM
2001 multi mode trans dirtrider9x 3rd gen T4Rs 8 02-13-2013 07:49 PM
Should I avoid a rig, if had strawberry trans, and trans was replaced?? Woodsie8 3rd gen T4Rs 4 03-25-2012 09:20 PM
V6 Gas Mileage: 2wd mode VS 4wd mode the_josh 4th Gen T4Rs 0 11-12-2004 01:33 PM
