Old 06-25-2015, 09:23 AM #1
3rdgenfan 3rdgenfan is offline
3rdgenfan is on a distinguished road
Need some help with an electrical issue
Hey guys. I need some help to identify and help troubleshoot an issue I am having. The issue has been ongoing for about a year now. I just got back from overseas so now I can work on it.
I replaced the starter before I left to go overseas. What happens is when you leave the vehicle sit for a day or two. You go back outside to start it and its dead. My dad says sometimes not even 24hours it will be completely dead.I replaced the battery terminals thinking it was a loose connection and same thing.
My dad took the vehicle to autzone and had the electrical system checked. They told him it was a bad battery. Battery replaced. Same issue. Three batteries later I know its not the battery.
Is it possible the starter solenoid is bad and drawing power? I ask cause it is the last thing I have replaced before the issue occurred. If anyone knows the best place to start. I have a multimeter so, If you know some voltage test or something let me know. Any info would be helpful to the problem addressed. Thanks.
3rdgenfan is offline   Reply With QuoteReply With Quote
Old 06-25-2015, 09:50 AM #2
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
First let me tell you I NEVER trust autozone, but that's just me. Secondly assuming the battery is good, you need to see if you have an unusual amount of draw. If your multimeter supports amperage, disconnect the negative battery terminal and touch on lead to the post, and one lead to the terminal and this will tell you the amperage draw. It should be around 300milliamps if it's normal. If it's much higher, we can start to isolate it.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Old 06-25-2015, 03:59 PM #3
I have to get a new multimeter when I go buy a new one I will let you know what it says.
Old 06-25-2015, 04:22 PM #4
jeremyc74 jeremyc74 is offline
Banned
jeremyc74 is on a distinguished road
Banned
When you're looking for meters make sure you get one that will measure at least 10Amps DC. Most of them will, but I've seen some of the compact meters that will only measure that much current with a separate probe.
jeremyc74 is offline   Reply With QuoteReply With Quote
Old 07-01-2015, 11:55 AM #5
Picked up a multimeter.
Old 07-01-2015, 12:00 PM #6
OK good, now set it to the AMPS mode, and connect one lead to the Battery terminal(with it disconnected), and the other lead to the Battery post. Tell us what the reading is, or post a picture.
Old 07-01-2015, 01:12 PM #7
I think I did this right. Here is the picture. Correct me if I am wrong.
Old 07-01-2015, 01:17 PM #8
Banned
Banned
Is that with the ignition off or on? If you're getting that reading with the ignition off and no interior lights on, you have a parasitic draw somewhere.
You shouldn't have anywhere close to a full amp when everything is off. The first thing I would do is start pulling individual fuses, and see which one drops the current reading.
Old 07-01-2015, 01:39 PM #9
Yes that is with the power off.
Old 07-01-2015, 03:00 PM #10
Banned
Banned
I'd start pulling fuses then.
Old 07-01-2015, 05:08 PM #11
I figured out why it was so high. When i was doing it earlier the door was open. it did drop but I am still getting about 0.13 MA. I pulled the MPX-B fuse. BAM. Problem fixed.
I tried to do some research online. It turns out that it deals with the power windows and door locks. Anything else I can try or anyone know what else i can do?
Old 07-01-2015, 06:33 PM #12
.13 is not bad, anything under .3 should be fine. The MPX fuse is for the Body ECU, and could have been a problem, but not at that level. Your problem is elsewhere!
Old 07-01-2015, 08:14 PM #13
OkiSurf1996 OkiSurf1996 is offline
OkiSurf1996 is on a distinguished road
Since you've got the new multi-meter now, why not check and see if the alternator is truly doing it's job? Trusting AutoZone is one thing, verifying for yourself is another. If the alternator isn't keeping the battery up to charge it may drain just enough on a drive to not be able to restart after sitting for a bit.
OkiSurf1996 is offline   Reply With QuoteReply With Quote
Old 07-02-2015, 08:33 AM #14
Could you please explain how to do this check.
Old 07-02-2015, 08:36 AM #15
cashmoney cashmoney is offline
cashmoney is on a distinguished road
Start the engine and put the probes on the battery with it set to read DC voltage. Should be ~14.4v.
1989 Toyota 4runner
cashmoney is offline   Reply With QuoteReply With Quote
Electrical issue help please. t4rfredd Engines / Suspension / Wheels / Tires / Audio / Accessories 2 12-15-2019 05:06 PM
Electrical Issue Park 3rd gen T4Rs 6 11-28-2012 01:07 PM
electrical issue, help wcrocco Classic T4Rs 3 03-16-2011 05:44 AM
electrical issue 86 4 runner New Members 0 01-25-2011 10:14 AM
Electrical issue? Or???? GR8TSCT Classic T4Rs 9 12-20-2010 10:15 PM
