Originally Posted by tobers
Thanks for the help. Work demands has slowed my ability to make progress on it, but we are after it. It is now throwing a P0303 code for a misfiring 3rd cylinder. The shop replaced both 3rd cylinder exhaust valves.
I saw the work order for the valve job from the shop and I was a little surprised to see that there was no machine shop charge. I am a newbie at this. If a shop replaced 2 exhaust valves would there be a machine shop charge? Would they true the head? Test the other valves? Or just put the new valves in? In a standard valve job would they test compression after the work to be sure everything is OK?
We are bringing it in tonight and the shop is going to look at it. I'm just trying to get educated as to what standard protocol would look like in a job like this. Thanks. Rick
Misfiring 3rd I swap the plugs and wire and see if it fixes #3. If no I would look into that injectors and valve. Try to start with the easiest and cheapest parts and work your way up.
