Old 06-30-2015, 11:49 PM #1
KingSuper's Avatar
KingSuper KingSuper is offline
Real Name: Armen
KingSuper is an unknown quantity at this point
KingSuper's Avatar
Real Name: Armen
Door wont open from inside
My driver side door will no longer open from the inside, I have to roll the window down and use the exterior door handle to let myself out! I've had my truck (1997 Limited) for less than a month. The first week the door worked but it was a littler rough when I used the door handle from the inside, like it was grinding on something. It would also not work if the lock was even slightly depressed.
Now the interior handle doesn't function at all, but is now smooth, no more grinding feeling. Locks work fine.
Anybody experience this issue before? Any resources you guys may be able to point me toward that will help me out? I am no mechanic, but am handy enough with tools. Would love to avoid the mechanic on this one.
KingSuper is offline   Reply With QuoteReply With Quote
Old 06-30-2015, 11:55 PM #2
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
You'll need to remove the door panel, and look at the rod that connects to the inside door handle. Most likely the clip that holds it in place is broken.
Or the door handle itself is broken.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Old 07-01-2015, 12:22 AM #3
kball's Avatar
kball kball is offline
kball is on a distinguished road
kball's Avatar
Here's a write up I did about the lock, might help you with the visuals.
Door lock replacement 96 runner
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
kball is offline   Reply With QuoteReply With Quote
Old 07-01-2015, 03:07 PM #4
KingSuper's Avatar
Real Name: Armen
KingSuper's Avatar
Real Name: Armen
Thanks guys I'll attempt to fix next weekend
ɹǝʌo ǝɯ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
door , handle , lock
Door won't open from inside or outside MillerPKA 3rd gen T4Rs 15 07-29-2018 08:18 PM
Door wont open =\ 4runnin83 Classic T4Rs 10 09-13-2012 11:03 AM
inside Door handle will not open door rubberball 4th Gen T4Rs 10 06-30-2010 11:10 PM
Door won't open from the inside 97blkt4r 3rd gen T4Rs 14 04-05-2010 10:06 PM
