Old 07-01-2015, 01:53 AM #1
beyond beyond is offline
beyond is on a distinguished road
Tailgate window stuck Down!
(Disclaimer) yes, I have been using the search function. Ive found a little help, but Im mostly going in circles
... and yes, the drivers window lock is unengaged.
'97 sr5 218Kmi
Issue: The I noticed the rear tailgate window down all the way, while I was driving to work.. I dont recall lowering it myself.
-When I hit the rear window switch I hear a relay clicking on the up position, but NOT on the down position.
-Both the rear wiper and rear defroster are non-functioning as well
Ive read a lot about this issue, but 99% of the scenarios are with the rear in the close to shut (up) position; where mine is the opposite.
PLEASE, anyone, offer any advice; Central PA this summer is getting a lot of rain and I cant afford to drive around with no rear glass
Thanks and cheers
beyond is offline   Reply With QuoteReply With Quote
Old 07-01-2015, 02:49 AM #2
D Farms's Avatar
D Farms D Farms is offline
D Farms is on a distinguished road
D Farms's Avatar
make sure the window lock button is not pushed.
'02 Toyota 4Runner SR5
E-Locked | Geared | Mid-Travel | 35s | Armored | 100% Chooched
D Farms is offline   Reply With QuoteReply With Quote
Old 07-01-2015, 02:51 AM #3
OkiSurf1996 OkiSurf1996 is offline
OkiSurf1996 is on a distinguished road
True statement. Worked for Toyota for a bit and this was 90% of the problem when people came in with the rear window stuck down.
OkiSurf1996 is offline   Reply With QuoteReply With Quote
Old 07-01-2015, 02:54 AM #4
D Farms's Avatar
D Farms's Avatar
lol when this was my dads truck we went skiing and it got stuck open. the defroster and wiper are disabled when the window is down, as well as the fluid. haha, that would be great if you had some friends in the back and whenever they would lean out you could squirt them, then hit em with the wiper.
Old 07-01-2015, 06:57 AM #5
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
First thing is to check all the wires in the harness that goes between the liftgate and the body for broken wires or insulation. Liftgate weirdness usually starts there.
My Backyard Frame Swap
Old 07-01-2015, 09:32 AM #6
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
'97 sr5 218Kmi
Thanks and cheers
Yes, it's not the window lock!
OK, as @TheDurk stated, check the harness where it comes out of the body and into the rear door. Also, am I to understand you think it was suddenly down but you didn't lower it? Could it have fallen off of the regulator? I know it's unlikely based on the design. Here is the blow up of what's inside.
http://tacoma.site40.net/4Runner_96-...acdoo/comp.pdf
Also, what happens if you try using the key at the back door?
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Old 07-01-2015, 12:08 PM #7
Well sure as shizz...
I manually powered the liftgate motor and it closed the window. I also checked the wiring harness but found no snags or splices.
When I hooked the motor back up it started to drop the window... I assume its a bad switch, but at least I'm able to raise the glass manually.
Thanks to everyone for your help
Old 07-01-2015, 03:37 PM #8
sportscarfan's Avatar
sportscarfan sportscarfan is offline
sportscarfan will become famous soon enough
Same thing happened to mine and I had to put the window up the same way.
If you take the panel off again, locate and remove the short section of wiring between the lock cylinder and where it plugs into the harness. I believe the short is in the green yellow piece that snaps onto the lock cylinder. I intended on replacing mine, but the switch inside still rolls it up/down and I don't miss the key activated feature...it's been about 3 years without it now.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
sportscarfan is offline   Reply With QuoteReply With Quote
Old 10-31-2019, 10:13 PM #9
Devon Nullman Devon Nullman is offline
Devon Nullman is on a distinguished road
Thanks, I thought of every possible thing EXCEPT that
Devon Nullman is offline   Reply With QuoteReply With Quote
Old 07-04-2020, 11:40 PM #10
CharlesDan CharlesDan is offline
CharlesDan is on a distinguished road
Hello I am having the same problem.
How did you manually powered it up?
CharlesDan is offline   Reply With QuoteReply With Quote
Old 07-05-2020, 12:08 AM #11
Pj Benn Pj Benn is offline
Pj Benn is on a distinguished road
I’m guessing he used some 12v leads
Pj Benn is offline   Reply With QuoteReply With Quote
Tailgate / back window doesn't work (motor works and it isn't the window lock switch) seattlee 3rd gen T4Rs 17 04-03-2022 08:58 PM
tailgate stuck locked 91yota-sr5 Classic T4Rs 7 10-08-2018 12:05 PM
WTB: 1st gen 4runner Hardtop DS window/ rear tailgate window got_rwd? Want to Buy/Trade 2 03-29-2013 03:46 PM
Stuck Tailgate rrcast 3rd gen T4Rs 3 04-26-2011 07:12 PM
Tailgate Window getting stuck on Rear Wiper. Help! tineman06 3rd gen T4Rs 7 10-05-2009 10:31 PM
