07-06-2015, 02:01 PM
Toytec Boss - Vibration Diagnosis - Pic Heavy
So I'm sure some of you have seen me griping on here about my new vibration I have (60mph+) after installing Toytec Boss and BF Goodrich KO2s. Well I have been doing some heavy searching trying to pin down the issue.
So a quick recap, I had the lift installed and got new aftermarket UCAs and new lower ball joints also. The vibration was much worse, however, I had the shop rebalance and adjust the alignment and it got better... But still bad enough that I can't see myself driving it like that after spending all of this money.
I have noticed that if I am going down the highway at ~65 while I am feeling the vibration I can put the T4R in neutral and the vibration goes away, or at least seems to. I still have the factory wheels and tires from pre-lift. I am thinking of putting those wheels/tires back on and testing it out. If it were a balance issue this should isolate that correct?
I saw someone this morning saying something about upgrading to the new style steering rack guide. I got down and looked and I already have that. The shop that did my lift told me it looks like someone had the steering rack replaced recently. (I have only had the 4runner for a couple of months)
I am posting a bunch of pictures. Everything is extremely clean. The discoloration on the steering rack is some oil splatter from a leaking valve cover I just recently tightened. Does anything look out of the ordinary. CV axle angle? Tie rods? Anything? I am desperate. Thanks!!
07-06-2015, 02:04 PM
I apologize I am not certain how to shrink the pictures or I would do it.
07-06-2015, 04:14 PM
Put your old wheels and tires on and see if it gets any better.
I'm thinking its either your wheels aren't balanced correctly or your alignment wasn't done correctly.
A poorly balanced wheel typically gets vibrations around 55mph-65mph
Good luck
07-06-2015, 05:05 PM
Banned
Banned
The fact that you say it changes when you put the transmission in Neutral makes me suspect it's something with the rear, possibly driveshaft pinion angle.
How much lift did you do here? Those CV joints look like they're at a pretty substantial angle compared to what I'm used to seeing on mine. It could be that you have one that's worn out and adding more angle made it more apparent.
07-06-2015, 09:46 PM
Approximately 2.5 inches in the front. Both sides appear to the same in appearance angle wise. I tugged on them and don't get any movement... But I agree, the angles look pretty harsh. Even the shop agreed.
07-06-2015, 10:40 PM
Originally Posted by sport05
.....Does anything look out of the ordinary. CV axle angle? Tie rods? Anything? I am desperate. Thanks!!....
I'm assuming you put in a diff-drop?
If ya always do what ya always done, Ya always gonna get what ya always got.
07-06-2015, 11:29 PM
Whats your mid hub to fender measurements? If your measurements are more than 22.5-23 inches, theres a good chance your lift is more than 2.5-3 inches which could explain the steep angles.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
07-06-2015, 11:51 PM
Real Name: Jon
Real Name: Jon
Welcome to the joys of a lifted 3rd gen you're always going to be chasing down a vibration, shake, squeak, click..... The fun just never ends but at the end of the day...
98 T4R Limited-elocker-OME 883/891-Stubbs sliders-285/75/16 General Grabber AT2-LC wheels-Savage skids-Satoshi-front and rear CBI hybrids-Smittybilt XRC 9500
Link to Build Thread http://www.toyota-4runner.org/3rd-ge...ld-thread.html
07-07-2015, 12:23 AM
This could be a newb suggestion, but have you balanced your tires recently?
07-07-2015, 12:39 AM
Real Name: Scramble
Real Name: Scramble
Um...yea he did it twice, read his first post.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
07-07-2015, 01:22 AM
Real Name: Alex
Real Name: Alex
So when it "seems" to go away when in nuetral, does it go away, or does it not? Does it only shake when under load, or also when just coasting but in gear?
All I see in the pictures that throw red flags are the worn sway bar endlink bushings, and aftermarket LBJs... The latter of which COULD be why it got worse after you replaced the UCAs and LBJs.
When the vehicle shakes, does the steering wheel shake?
Edit** Looking again... Your CVs are pretty angeled, but I doubt that's an issue that wwould cause the shakes. And that grease everywhere is a turn off
2006 Lexus GX 470 Sport- RR Diff Lock, Metal Tech Sliders, RCI Aluminum Skids, Front Runner Slimline II Rack, SCS F5s, 255/80R17 ST Maxx , OME BP-51s, Dirt King UCAs, Metal Tech RR Lower Links
2016 Lexus IS300 F Sport- F-Sport Air Filter RR Racing tuner
07-07-2015, 02:00 AM
Real Name: Instagram: briansd_97r
It appears from the picture that your LBJ is leaking. That would be a big concern to me.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
07-07-2015, 07:55 AM
Diff drop was installed.
"Whats your mid hub to fender measurements? If your measurements are more than 22.5-23 inches, theres a good chance your lift is more than 2.5-3 inches which could explain the steep angles."
Measured just a minute ago. 23.5 on both sides.
"It could be your drive shaft/double cardan joint/universal joints..."
- no idea about any of that.
"So when it "seems" to go away when in nuetral, does it go away, or does it not? Does it only shake when under load, or also when just coasting but in gear?"
It goes away. I tried it out again this morning.
"It appears from the picture that your LBJ is leaking. That would be a big concern to me."
No I don't believe so, I just had them replaced two weeks ago. That was excess grease. Its been there since the install, before it had even been driven.
Thanks for all the input
07-07-2015, 08:41 AM
I just came in here to admire in jealousy the rust free chassis.
1997 4Runner Limited V6 Auto 4x4 w/E-Locker - 184K Miles
OME 881/890 Springs, Tokico TrekMaster GU3535/GE3536 Shocks, 1" Front Diff. Drop, Front Frame Mounted D-Rings
All-Pro 1.25" Hubcentric Wheel Spacers, 265/75R16 ETS Trail Master M/T, B&M 70268 Cooler (bypassed)
2010 Matrix XRS 2.4L 5-Speed - 130K Miles
