09-22-2015, 01:16 AM
#46
Real Name: Mason
Real Name: Mason
I tried the whole thing again on a different lap top. Same thing happened. Could my aic be bad? I'm going to try a different cord if I can find one local. Best buy has a 1' one, lol.
1998 4x4 5speed E-locked 225k - TRD 2nd Gen Charger w/ URD 7th injector - ICON 2.5 Standard Coilovers, ICON 2.5 Rear w/ Remote Res, ICON FJ Shin Guards, stock UCA, Tundra 199mm, ARB Bumper, Custom Tire Swingout bumper, Custom low profile roof rack, Lotas LC, Stubbs HD-SKO, 265/75/16 Duratrecs on OEM 5 Stars, Shockworks Combo Skids, Lightforce Genesis 210 halogens, 20% front tint, Uniden 520Xpro, 99+ Cup Holders & Headlights, Clarion CX501 deck, UG scanner, rear diff mod
2003 V8 4x4 Limited Black 156k stock for now. ICON ordered
09-22-2015, 09:48 AM
#47
Sweet, just bought a used 4th gen supercharger and 7th injector. The info on the supercharger thread gets more confusing by the day it seems. Looking forward to this.
09-22-2015, 10:14 AM
#48
Real Name: Mason
Real Name: Mason
Congrats but this looks like a direct copy for my first post on this tread?
09-22-2015, 02:36 PM
#49
Real Name: Charlie
Real Name: Charlie
Looks like a spammer
Originally Posted by STX4Runner
90% of the build threads in the 5th Gen section consist of Fuel Wheels, Plastidip, Duratracs and window tint.
1998 4Runner "Diamond" - Daily Driver (rolled & rebuilt) - 3.4 5-Speed, Coastal Bumper, Manual Hubs, 255/80r17 AT3Ws (409k+ Miles)
1997 4Runner "Becky" - Camping Rig - 3.4 Auto (for now), Armored, Cable E-Locked, Coastal Bumper, Sleeper Deck, 255/80r17 AT3Ws (185k+ Miles)
1989 4Runner | Tennessee 4Runner Group
09-22-2015, 05:09 PM
#50
Real Name: Mason
Real Name: Mason
I did another test today. This time I supplied no power to the truck (no key in ignition) and tried to connect to the AIC. The R4 program again did the same countdown and gave me the same error message telling me to check the connection or power. I'm thinking maybe my AIC is not getting power. What wires would I check for power to the AIC?
09-22-2015, 09:06 PM
#51
Go back to the installation instructions and see what one is a 12v power supply. Mont of the wires you installed or tapped into are signal wires for sensors.
On a side note, do you have a afr gauge? Is your 7th spraying? If it is then you will have power to the AIC
Never ask a girl if shes sick, she might not be wearing any make up. - lets just say she went storming off.
Never tell your wife she looks tired, they tend to hit and say that means she looks ugly. (weird logic i know)
09-22-2015, 09:09 PM
#52
He does, but the afr wont tell him anything most likely since at wot the AFR's should be good and the midrange could just be out of tune...
09-22-2015, 09:23 PM
#53
URD 7th Injector Tuning Guide
No,
I'm trying to see if his injector is spraying. If not than it might lead to why he can not connect to the AIC.
09-22-2015, 09:43 PM
#54
No,
yep and I am telling you it won't tell you anything unless his tune is setup right. The AIC could be working fine, but the injector might be setup to spray at 24 psia which means he may never see it. If his rig is anything like the others that I have seen, he will be right around 11.7-12 AFR even if it isn't spraying at wot.
09-22-2015, 10:46 PM
#55
Real Name: Mason
Real Name: Mason
Which would be the power source. If the AIC was not powered then I'm sure the 7th woukd not be powered either as the 7th injector gets its power from the AIC...
09-23-2015, 07:58 PM
#56
Real Name: Mason
Real Name: Mason
Lol, bump. Any ino on where the AIC gets power from my wire diagram?
10-08-2015, 01:56 AM
#57
hey i see your online. did you get your problems figured out?
12-07-2015, 09:59 AM
#58
Make sure you downloaded the driver for the cable. That's the problem I had and was exactly what you were saying. The cable should have come with a disk
00 4Runner 3.4 v6 SC 4wd swapped lifted locked, armored
12-09-2015, 09:56 PM
#59
bump for some updates.
12-10-2015, 01:26 AM
#60
I had the same problem when I first set mine up, laptop wouldn't connect. What fixed it for me was rolling back my serial driver to a prolific driver that was much older than the newer version. This is one of those cases where keeping drivers up to date makes stuff not work. Search the web for prolific serial drivers and keep trying til you find one that works, guarantee it does.
96 SR5 - 300k - 5 Speed - 1st Gen Supercharger - URD 7th Injector - Denso IK22's -170° Thermostat - NGK Wires - Deckplate Mod - AFE Pro Dry S - Borla XR-1 - Toytec Eibachs w/Tundra Bilstein 5100's - Superflex w/Icon 2.0's - Diff Drop - Panhard Bracket - Goodyear Duratrac 285's - 16x8 XD Hoss Wheels - Rhino Lined Bumpers/Grille/Fender Flares/Wind Deflector - 99+ Headlights w/DDM 5k HID's - Clear Corners & Turn Signals - Black Eagle Eye LED Tails - Smoked LED 3rd Brake Light
