07-21-2015, 01:42 PM
#16
Update: Yesterday morning I went out to my car to clear the code and when I cranked it up, the lights were already gone.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
07-21-2015, 06:00 PM
#17
Originally Posted by TheDurk
There ARE codes for the EVAP system that will clear this way, but P1135 is not one of them. So I suspect your current code is something else.
I appreciate the reply. odd as it is the code on the reader was P1135. only thing I have done is loosen and retighten the gas cap and the warning lights are off. who knows when or if they will stay off. the next fill up may cause this again. I'll update as things happen. I have the A/F sensor on order and may wind up replacing anyways.... time will tell.
2002 4runner SR5 2wd
2005 Tacoma Prerunner 2wd
08-16-2015, 03:56 PM
#18
finally got around to changing the A/F sensor. codes cleared after three starts. for whatever reason the codes would clear for a short bit after refueling. don't know it just happened.
thankfully no problems with the 12mm nuts that secure it. no rust at all.....southern vehicle with clean underbody!!
thanks for the assist folks
08-16-2015, 08:07 PM
#19
I have no idea why a P1135 would clear after refueling. I don't even have a theory.
My Backyard Frame Swap
08-16-2015, 08:11 PM
#20
I have no idea why a P1135 would clear after refueling. The only thing I can think of is that maybe a pending evap code is clearing and causing a retest of all the monitors, clearing the P1135 temporarily. If you get an evap code in the future, that would confirm it. Really, only the evap codes have anything to do with refueling.
12-14-2015, 01:25 PM
#21
I just got the P1135 code, as well. Ordered the new sensor, but can I drive it until the part comes in and I get it swapped?
What are the consequences of driving without this sensor? Bad fuel efficiency? High operating temp?
Frey // TLCA# 21125
2002 4Runner SR5 3.4L V6 4x4 Auto
2003 GX470 4.7L V8
SOLD: 1997 4Runner SR5 3.4L V6 4x4 5-speed Manual E-Locker
01-25-2016, 06:00 PM
#22
I am interested in this as well as my truck threw the code this morning and I need to use it until I can get the replacement part (Wednesday). I drive at least 120 miles a day going to and coming from work.
01-25-2016, 06:14 PM
#23
Would recommend driving as little as possible. Depending on how your engine is running (mine was running 2% rich when my AFR sensor went), you could run the risk of flooding the catalytic converter. Someone here on the forum might have a little more information on how serious of a threat this is, but the thought of sending excess fuel into my converter made me a little nervous until I replaced the sensor.
This being said, I didn't realize that at the time and drove for another 1000 miles or so. Haven't seen any real issues yet including an inspection in NY.
On another note for those who will replace this sensor, be weary that the bolts holding the sensor into the exhaust may have completely corroded away depending on where you live. I had to use a hammer and a chisel to break apart the nuts WITHOUT damaging the screw boss that is attached to the exhaust pipe.
01-27-2016, 08:37 PM
#24
AF Ratio Sensor
The AF Ratio Sensor I ordered arrived this afternoon. It only took me a little over 15 minutes to change it out ( I took my time). I disconnected the negative battery terminal and pulled out the EFI fuse before I started. The codes were cleared when I was done and reconnected the battery. The 10mm bolt and 12mm nuts came out pretty easily, I did not even have to spray them penetrating oil. Having a rust free vehicle really helped. The hardest part actually is trying to squeeze in underneath the truck. I should really ditch the running boards soon
2001 Toyota 4Runner Limited 2WD
03-24-2016, 01:46 PM
#25
^^^^What he said. A/F sensor or associated wiring, period. No debate. As it is a heater failure, no way is that code due to the cats. When in doubt, RTFM:
Do you how this differs from a Cali emissions 4Runner with 2 cats and 2 02 sensors?...
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
03-24-2016, 02:03 PM
#26
Trick question, huh? There is no such thing. If it's a Cali two-cat system, it has an A/F sensor in front and O2 in back just like this one. Two O2 sensors means one cat, period.
ONLY an A/F sensor found on the Cali-type two-catters will throw a P1135.
03-24-2016, 02:36 PM
#27
My bad, not a trick question, just an ignorant question....
I went to the dealer and they hit me with $500 quote for the 2 sensors.
$312 for one & $273 for the other. Ouch
They had to look it up by my VIN.
Build Thread
03-24-2016, 05:59 PM
#28
You can get OEM Denso on Amazon at about $200 for BOTH, less if the front is an O2.
03-24-2016, 06:37 PM
#29
Sorry for blowing you up dude....I'm doing nube things over here
Can I remove the first sensor and see what part number is labeled on it?...
I have a 2002 Cali emissions...
Build Thread
03-24-2016, 10:15 PM
#30
No, I don't believe that there is a part number labeled on it. You can go to Denso's website to see what part is correct direct from them.
2015 T4R TRD Pro in super white, Morimoto 4300K HID kit, Auer Engineering / Toyota LED DRL/Fogs 2-in-1's, TRD drop in air filter, WeatherTech front and back liners.
2002 T4R SR5 4WD Onyx Black Sport Edition w/Leather. Gone but not forgotten.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
