Old 07-29-2015, 09:44 PM #31
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble has a spectacular aura about Scramble has a spectacular aura about
Scramble's Avatar
Real Name: Scramble
Originally Posted by Unner View Post
If you can I would recommend powdercoat. When I painted my grille I used SEM bumper coater which is supposed to be one of the best but the paint is getting worn off kinda by the bug hits on the front already. I will probably pull the grille at some point and have it painted at a body shop that can hit it with a good clear coat afterwards too. The front is going to see the most issues with paint because of bugs, stones, etc at 70 mph on the interstate. You could look for an industrial powdercoat place. That's where my sliders are right now, they just put mine in with a bunch of other semi gloss black stuff and only charged $40 because of that.
I could, it would cost me around $300 up here in N.NJ/NY. I cant justify paying that when Shrockworks would have done it for $100. I already bought the primer, paint & clear coat.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 07-30-2015, 10:22 PM #32
Scramble's Avatar
Real Name: Scramble
Scramble's Avatar
Real Name: Scramble
Question
So I was doing some research & read that you are not supposed to add color over self-etching primer. You need to seal it with a regular primer before spraying color. Never heard that before. This was at a car restoration web site during a Google search.
____________
Old 07-30-2015, 11:29 PM #33
csp csp is offline
csp is on a distinguished road
csp csp is offline
And what reason did they give for that? Link?
csp is offline   Reply With QuoteReply With Quote
Old 07-31-2015, 12:10 AM #34
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
I've done it both ways, came out just as strong and looked just as good either way, never heard of that but sounds like bs to me.
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 07-31-2015, 12:55 AM #35
Scramble's Avatar
Real Name: Scramble
Scramble's Avatar
Real Name: Scramble
It was a search I did at work. They said that self-etching primer is only to be used on bare metal (obviously) & you're only supposed to use 1 or 2 light coats. It's only purpose is for adhesion & is not to be sanded. It's transparent & will effect the top coat color. A few coats of regular primer should be used to seal it with sanding in between coats to provide a nice smooth opaque base for the top coat.
They were talking about high end paint jobs on restored cars & it makes sense to me especially if you are talking about lighter colors.
I'm in the printing business & different color substrates will provide different results with the same image & the same inks. I don't know if this matter's with a Black bumper but I'm gonna do it.
____________
Old 07-31-2015, 02:50 AM #36
UnderFire's Avatar
UnderFire's Avatar
Ok, that's definitely a concern when you're working with colors or especially white, you always want to have a neutral base coat so it doesn't show through the paint, with black, not so much. The times I've covered self etching or iron oxide primer with a top coat of 2-3 coats of automotive primer were times that I was going for a smoother finish, it's much easier to get a nice clean, smooth finish with a sand-able primer, with a self etching primer, there's nothing to sand, so if you spray your black over it, you pretty much get any imperfections that were in the surface, not really a concern on bumper, skids etc. for me, but some people like to get the best finish possible on everything.
If you're looking for a quick way to knock out imperfections, dirt, bugs, etc between your coats, look for 3M "between coats" pads, I've used them to get specs of stuff off of paint jobs in progress with great results, and as long as the primer your using builds up enough it'll completely hide the spot where it used to be.
Old 07-31-2015, 11:07 AM #37
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough JayRolla will become famous soon enough
JayRolla's Avatar
That is what I did on my rims first time. Decided it was too much work. Now I just use primer/paint in one can, works great.
Just to remember, your before prep work is so important, it makes all the difference, get all those oils and minerals off the bare metal.
The more coats the better and make sure paint never dries between coats, just 15 min to tacky.
JayRolla is offline   Reply With QuoteReply With Quote
Old 07-31-2015, 02:26 PM #38
BrandonF BrandonF is offline
BrandonF has a spectacular aura about BrandonF has a spectacular aura about
I got my rear bumper and sliders powder coated.
What I learned: Pick a good powder coating shop… My sliders have been fine but on the rear bumper, they did such a shitty job prepping the metal that its flaking off on the corners and they missed tons of spots on the inside of the bumper and its starting to rust lightly. It was surprisingly cheap and now I see why they don't charge more. Lesson learned.
BrandonF is offline   Reply With QuoteReply With Quote
Old 07-31-2015, 03:04 PM #39
ryhi's Avatar
ryhi ryhi is offline
ryhi is on a distinguished road
ryhi's Avatar
I use this stuff in satin black. Highly recommended.
VHT Roll Bar & Chassis Paint
02 4Runner 4WD 3.4 Sport Edition
ryhi's 4runner
99 4Runner 2WD 2.7 Base
ryhi's 4runner #2
ryhi is offline   Reply With QuoteReply With Quote
Old 07-31-2015, 08:15 PM #40
csp csp is offline
csp csp is offline
You can sand self-etching primer. That bit about sanding means that in auto body work terms it's not a high-fill type primer meant for filling imperfections and block sanded. That's not the process you're going to go through painting a bumper. I sanded my etching primer with no problems or sand through back to bare metal.
The stuff in a spray bomb can, like Duplicolor, is not transparent. If it were you'd see the metal through it. ANY primer can affect the color of the top coat of lighter to medium colors. Not so much with black.
No harm adding another type of high build filler, but it really serves no purpose in this application.
Personally I don't use self-etching primer on body work. Epoxys do a MUCH better job and actually seal the metal against moisture. Self-etching and high build primers are permeable and need to be top coated as soon as possible. I can get a panel prepped for primer, spray it with epoxy primer and forget about it for any length of time.
Old 08-18-2015, 02:23 AM #41
Scramble's Avatar
Real Name: Scramble
Scramble's Avatar
Real Name: Scramble
My bumper came out nice, we'll see how it hold up to rock chips. Getting the surface rust off the inside of the bumper was a real pain as was getting the primer/paint into all of those nooks & crannies.
Surface rust:
Wire wheels, Dremel & 80 grit on the angle grinder polished it up nice.
____________
Old 08-18-2015, 02:38 AM #42
Scramble's Avatar
Real Name: Scramble
Scramble's Avatar
Real Name: Scramble
2 thin coats of self etching primer:
3 coats of primer, sanding the last coat with 320 grit.
This pic has about 3 thin coats of Black, I ended up doing 6 thin coats.
I sanded the Black with 600 grit before adding the last coat. It's real smooth & looks professionally done.
____________
Old 08-18-2015, 02:55 AM #43
Scramble's Avatar
Real Name: Scramble
Scramble's Avatar
Real Name: Scramble
2 more
____________
Old 11-27-2021, 03:54 PM #44
bryanbgw's Avatar
bryanbgw bryanbgw is offline
bryanbgw is on a distinguished road
bryanbgw's Avatar
Did you end up going with the semi-gloss or flat black?
bryanbgw is offline   Reply With QuoteReply With Quote
My New Custom Front Bumper robaroni 4th Gen T4Rs 6 02-21-2015 05:35 PM
Custom Front bumper? WS4Runner 3rd gen T4Rs 10 10-15-2011 12:01 AM
Custom Front Bumper PaulSula Off-Roading 31 04-08-2010 11:59 PM
F/S 4th gen custom front bumper Good Times Classifieds - buy & sell (no commercial ads please) 5 05-30-2005 03:01 PM
