08-16-2015, 08:48 PM
#46
My first toyota, coming from a jeep. Always wanted a 4runner but couldn't afford one. Picked this up with a blown motor. Been trying to find a replacement motor but they are hard to find up in Canada!
08-16-2015, 11:36 PM
#47
I had to do a bunch of engine work to mine, and ended up having a machine shop rebuild the entire thing. i looked at JDMs, and used but couldn't find a good one. I tried looking at tacoma motors too, most of them seem to be distributor type, instead of the coil type ignitions that 4Runners (at least mine) have.
I know a lot of guys on here swear by OEM, and thats all fine and good when you can find it. I would look into having yours rebuild if possible.
Whats wrong with it?
If ya always do what ya always done, Ya always gonna get what ya always got.
08-16-2015, 11:49 PM
#48
The style of ignition is based on when the motor was built, not if it was in a Tacoma or 4Runner. Just a little tidbit of useful info.
95.5 - 96 (Maybe early 97) had the distributor, 97 - about halfway through 2000 was the wasted spark 2 coil setup, and after that they had a coil on plug setup.
'97 3RZ 5 Speed "FrankenRunner" ( Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - ( Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
08-17-2015, 12:01 AM
#49
Good to know. I just mentioned the difference since most JDMs out there were dizzy ignitions.
08-17-2015, 09:37 PM
#50
I'm thinking that my best bet is to rebuild it then. Previous owner said there was a knock and I bought it with the engine ready to be pulled so I kind of have no idea what's really wrong yet. Top end looks good so far but I still need to drop the oil pan. Definitely seized as I can't crank it over with a ratchet. Picked it up for $700 and it is almost rust free! It's my first toyota so I hope it's worth spending the money on
08-17-2015, 10:38 PM
#51
Once you get her back up and running, she'll treat you good for years to come, one thing I can definitely recommend if you end up going with a rebuild on your current motor is doing the balance shaft delete and a set of cams, that really wakes up the engine quite a bit. I'd really like to do it to mine, but I'm too cheap and it's my daily lol.
08-17-2015, 11:11 PM
#52
Real Name: James
Real Name: James
Originally Posted by ChildrenOfBodom
My 1999 4Runner 3RZ over the years
COB, Your truck has always been an inspiration. I can only hope that over the years i can build mine like yours
08-18-2015, 03:07 PM
#53
Progress over the years. 255K on the clock. Had this car since I was 15 and amazes me how I can always count on it to get me from A to B. Nice builds everyone!
'96 4Runner 2.7L 3RZ
OEM Toyota 6” fog lamps, OEM Hilux Surf clear corners, OEM Hilux Surf turn signals, OEM Hilux Surf fender mirror, OEM Hilux Surf Power Mirrors (not PFM), OEM Hilux Surf window visors, OEM Hilux Surf rear spoiler complete with power mirror, OEM Hilux Surf “Limited” fender flares complete with running boards, OEM Hilux Surf badges, JDM KaddisEarly Mudflaps (black), JAOS Front Skid Plate, 16x8 -25 Weds Adventure Hase Spec
09-06-2015, 05:43 PM
#54
Real Name: Durwin
Real Name: Durwin
I started a thread Engine noise? 3RZ experts please help asking for help with engine noise.
If any of you have insight, I would welcome it.
Thanks
Durwin
99 2.7l 5spd ARB locked F & R, 5.29's, dual cases, Shrockworks front bumper w/ Warn M8000s, King 25001-151EXT coilovers, OME 861/LC shocks, Stubb's sliders, Shrockworks full skids, custom built rear bumper, Kenda Klever RT 35x10.5r17 on FN FX pro 17x8's, TBU
09-06-2015, 10:36 PM
#55
This is where the party is!!!!
What's up fellow 3RZ'ers? I thought I was alone out here in my 4cyl beast. I am glad to see I am not alone and look forward to hearing about anything you guys have found or come up with to make The 3rd gen 4cyl rock a little harder.
09-06-2015, 10:40 PM
#56
yeah, its called a 3.4
Giant Motosports
09-06-2015, 11:02 PM
#57
Real Name: John
Real Name: John
Lc header and a full exhaust help some. A piggyback a/f tuber helps too.
Cams, turbo, supercharger, valve springs, headwork and lots more is out there for the 3rz......unlike the 5vz which has a supercharger and very little else.
98 Toyota 4runner 3rz 5spd 4x4 - Sold Build Thread
06 4runner 2uz Build Build Thread
Instagram: @Kryptowerkz
#58
There's a ton of info on boosting our little RZ motors over on Customtacos.com, it's definitely a solid motor for adding a turbo.
09-20-2015, 06:01 PM
#59
Real Name: John
Real Name: John
So I have a question for us 3rz owners. I achieved more lift from the 99 springs than just 1" and the front is kinda bouncy. What I'm thinking of is instead of running the tundra trd setup with 5100s getting my hands on some tacoma trd springs for the v6 and running those with the 5100 for the tacoma. Thoughts?
09-22-2015, 06:25 PM
#60
Real Name: Justin
Real Name: Justin
Saw this on craigslist and I thought I would share it with the 3RZ guys. I have no affiliation or have no idea if it is still available. This is the first time I have seen one of these for sale.
TRD Supercharger
