07-23-2018, 10:24 PM
#391
Real Name: Scramble
Real Name: Scramble
After 2 weeks at the shop my 4.56 E-Locked 3rd member was ready!
I put her on my outdoor work table & gazed at her beauty!
IMG_2526 by Mike Campbell, on Flickr
IMG_2527 by Mike Campbell, on Flickr
IMG_2528 by Mike Campbell, on Flickr
The shop doesn't use that backlash grease. They measure pinion depth before & after the rebuild. They said it was spot on. I wanted to double check it so I Googled what else I could use that I had around the house & lipstick was something that I had. Not mine! My GF's! LOL
It was dead on.
IMG_2530 by Mike Campbell, on Flickr
20170902_121132 by Mike Campbell, on Flickr
20170902_121150 by Mike Campbell, on Flickr
Here's the 4.30's & my old carrier. I have them boxed up for a rainy day.
IMG_2531 by Mike Campbell, on Flickr
I bought the Low Range Off Road E-Locker harness from a member in the Classifieds for $100. Thats half off new. He sold his 3rd gen before doing the e-locker swap.
IMG_2529 by Mike Campbell, on Flickr
ultimate_toyota_elocker_wiring_harness_kit_1000px by Mike Campbell, on Flickr
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Reason: Sept 2, 2017
07-24-2018, 12:06 AM
#392
*liked* just for that Judas Priest Sticker.. I need to get that
2000 Limited, 2021 SR5
07-26-2018, 08:34 PM
#393
Real Name: Scramble
Real Name: Scramble
September 2017
I followed the instructions on the Permatex label. I put a nice steady bead on the housing & around both sides of the studs. Set the carrier down carefully, "hand" tightened all of the nuts with my ratchet & let sit for an hour while I went in & had lunch. After an hour I tightened down by feel & then gave one more full turn. If you're an amateur use a torque wrench because these studs can snap pretty easily.
20170902_185632 by Mike Campbell, on Flickr
IMG_2534 by Mike Campbell, on Flickr
Here you can see a little of the Grey Permatex oozing out.
IMG_2535 by Mike Campbell, on Flickr
IMG_2536 by Mike Campbell, on Flickr
____________
08-22-2018, 10:15 PM
#394
Real Name: Scramble
Real Name: Scramble
After letting the Permatex dry for 24 hrs I started to de-grease the axle housing. I was gonna use the pressure washer but I was afraid to get water inside and/or damage any of the electrical connections on the actuator. I used POR-15 De-greaser & blue shop towels.
I bought a quart of Eastwood rust encapsulator & applied the first coat by foam brush. I was really hoping for a smoother finish but this stuff dries fast & the only way to make it smooth is by spraying.
https://www.eastwood.com/eastwood-bl...over-rust.html
IMG_2548 by Mike Campbell, on Flickr
I used a can of Eastwood's Internal Frame Coating w/ the 360* nozzle to get into all of the spots that a brush wouldn't reach. Thats what those drips are on the cardboard, that shit flies out.
IMG_2541 by Mike Campbell, on Flickr
IMG_2542 by Mike Campbell, on Flickr
I let it sit until the following Sat & sanded the housing with 320 grit to get a smoother appearance & also to get good adhesion for the second coat.
I figured I'd try to spray this with my Wagner Stain sprayer that I used to do my deck. I diluted the paint with lacquer thinner & it worked pretty good. I wasted a pretty good amount of paint because the nozzle was too small but it got the job done.
https://www.amazon.com/Wagner-041700...+paint+sprayer
IMG_2550 by Mike Campbell, on Flickr
IMG_2551 by Mike Campbell, on Flickr
Let dry for 1 hour & added 2 coat's of Satin Black VHT Roll Bar & Chassis Paint.
IMG_2552 by Mike Campbell, on Flickr
IMG_2553 by Mike Campbell, on Flickr
IMG_2555 by Mike Campbell, on Flickr
IMG_2556 by Mike Campbell, on Flickr
Old perfectly fine axle housing in the background.
IMG_2557 by Mike Campbell, on Flickr
____________
08-22-2018, 10:42 PM
#395
Real Name: Scramble
Real Name: Scramble
Shrockworks charged my card today for the rear swingout bumper! Should ship tomorrow.
I already have a matching Trail Edition wheel & ordered the Sonoran Steel body mounts a few weeks ago.
Today I ordered a Hankook 285 matching spare from DTD! Nice!
____________
08-22-2018, 11:13 PM
#396
Real Name: Ryder
Real Name: Ryder
Cool! I know you have been wanting that rear Shrockwors swing out for a while now. Congrats!! Looks like you will be ready to go when it lands. I look forward to seeing it on your rig.
08-22-2018, 11:27 PM
#397
Real Name: Scramble
Real Name: Scramble
Yea man, I've had that TE wheel for like 2 years now. LOL I like to plan ahead.
Last year when I was painting the rear of the frame I started messing with the stock body mounts. They were pretty rusty & didn't budge. I had the rear bumper off so every weekend I'd hit them with WD40 & give them a little tug. After a few weeks they eventually cracked loose. I never tightened them back up so they should come out no problem. Now I need to figure out what gas can to get. I really needed it on my last wheelin' trip.
____________
09-18-2020, 08:29 PM
#398
Real Name: Jeff
Real Name: Jeff
It's been a long time and I was thinking about your 4runners. I hope everything in NY is going okay for you. Any updates on the property and garage? Or cars and dogs?
97 SR5 4runner: 2" OME Lift, rear E-Locker, 231mm Tundra Brakes, 203K, B&M 70264 Tranny Cooler, Duratracs
Build
02-04-2021, 05:36 PM
#399
Real Name: Scramble
Real Name: Scramble
Hey Man,
Thanks for checking in! Hope all is well with you & everyone else in this forum!
Well Covid screwed up lots of things. Me & my GF have been out of work since last March. She just started a new job last week so thats good. I'm on furlough, my boss says he's taking me back when work picks up but I only have 11 weeks of unemployment left. I was the night supervisor & there's not enough work to open up at night. They've laid off 100 of our 200 employes & only open from 7-3pm.
The garage is cleaned out but I have no money for the cement floor & other updates I wanted to do to it. I'm late on the property tax for the land. Unemployment doesn't even cover my bills forget about the luxuries that I've had. I've been taking money from my retirement to stay afloat.
The dogs are good except my Shepherd Eros. He's 11 & has Lou Gehrig's disease. He's having trouble with his hind legs now. He brain is fine but walks like a drunk. Not sure when we'll have to put him down yet. Probably when he cant make it outside to go to the bathroom.
I'm not sure if I posted about my 3rd 4Runner. It's a fully built '99 E-Locked Limited with a rotted frame. Only has 144K on the clock. I drove it home but the frame is bad! Got it cheap & the e-locker axle was an add on so no rust on that. ARB bumper, TRD wheels w/ Duratracs, 3" Toy-Tec lift, CVJ axles, mint leather interior. I could part out a few things & break even easily. Or do a frame swap & have a really nice truck or keep it for parts. If I'm still out of work in the spring I'll have to part it out but I'd rather not. It runs & drives fine.
Here's a pic of all 3 in my front yard. Take care!
____________
02-04-2021, 08:10 PM
#400
Neice Harem of 3rd gens. Good find on the runner. Its tough when dogs get old. I ve lost two, a 13 yr old GSP and a 12 yr old boxer. It's good to hear from you. Covid+ the shitty response for the working man and women did a number. Times are tough all around hope to God it gets better in a hurry. lots of my friends moving in with their families cause they can't afford the houses and expenses. All I can say is you are a strong Newyorker and I am sure you'll come out on top. Wish you the best.
