Old 02-04-2021, 06:44 PM #1
calicojax's Avatar
calicojax calicojax is offline
calicojax is on a distinguished road
calicojax's Avatar
99 fuel gauge *FIXED*
I'll be as short as I can... not sure if he is a member here but there is a guy on YouTube "phorunner". I've tried it all. And this finally worked for me.
calicojax is offline   Reply With QuoteReply With Quote
Old 02-04-2021, 07:30 PM #2
Twan's Avatar
Twan Twan is offline
Twan will become famous soon enough Twan will become famous soon enough
Twan's Avatar
I'm going to assume that you're talking about this video:
http://www.youtube.com/watch?v=KNbMq7VvpdI
2000 SR5 Sport - 4EAT and E-locker, King 2.5s, EimKeith PCK, SPC UCAs, 33" KO2s on Black Rhino Boxer gloss gold 17x8.5, Savage/Lotus skids, 4xInnovations front bumper/sliders, Shrockworks bumper & tire carrier, Lil Skip Gas Tank Skid, Magnaflow Overland cat back
Twan is offline   Reply With QuoteReply With Quote
Old 02-04-2021, 07:35 PM #3
spartacus's Avatar
spartacus's Avatar
Phorunner's got a sweet rig.
Old 02-04-2021, 08:05 PM #4
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
That's awesome this worked for him, don't use those vampire clips though!.
There is a TSB EL010-00 for this very problem on Oct 98 to early 2000 4Runner, they came off the line with faulty parts, should have been a recall as it is a safety issue!, some had to replace the sending unit and inclinometer chip in the dash which deletes your current Odometer unless you fill out the request provided in the TSB or you take it to a electronic specialist familiar with this Toyota & Lexus TSB/problem, the dealer isn't equipped to transfer the Odo data to the new chip and will have you sign off on the Odo Change and likely won't tell you till after the TSB is performed that you had this option when ordering the new circuit board/inclinometer..
https://www.toyota-4runner.org/attac...t-el010-00-pdf
Malcolm99 is offline   Reply With QuoteReply With Quote
finally , guy , phorunner , worked , youtube
Fixed... Gauge, AC Compressor, and Alternator Regulator Failure sam.basye 3rd gen T4Rs 43 10-10-2019 12:42 AM
WTB 3rd gen gauge assembly w/ working fuel gauge technodrive Want to Buy/Trade 3 08-05-2015 03:07 PM
Tach, Fuel Gauge, Temp Gauge, Oil Pressure Gauge, Alternator Quit Working silentrunner Classic T4Rs 3 10-05-2013 12:51 PM
2005 4x2 sr5 4.0 temperature gauge/fuel gauge Josh05 4th Gen T4Rs 0 09-10-2013 04:39 AM
Fuel Gauge problem fixed! thatgreentruck 3rd gen T4Rs 1 05-09-2012 12:38 PM
