Old 08-03-2015, 10:51 AM #16
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Originally Posted by tripsydipsy View Post
That is the method I chose. Thanks for the response Kanoe! I didn't have any white smoke coming out of my exhaust afterward.
Did you pour it in, or let the engine suck it in? You should have white smoke, unless it went in too slow and burned it all off or it found its way into something it was not supposed to.
I ended up with a can of seafoam spray and tried that for kicks and it's way easier to use and just as effective in my case. Also, having someone apply a little throttle goes a long way when applying.
Seafoam does work but it's a just a quick-fix sort of thing. I never saw any huge improvements from any of my vehicles but definitely cleaned out a lot of carbon from the engine.
326WHP 347TQ
Old 08-03-2015, 09:12 PM #17
tripsydipsy tripsydipsy is offline
tripsydipsy is on a distinguished road
I poured it in through an egr line. I think it might have burned it off too fast because I did have my brother revvin at about 2k rpm the entire time I was pouring it on. I only poured 1/3 of the bottle in.
tripsydipsy is offline   Reply With QuoteReply With Quote
Old 08-03-2015, 11:17 PM #18
Real Name: Jerod
Real Name: Jerod
Take off your air intake hose and check the chambers in it. 10 bucks says you'll pour out a puddle of seafoam. I did it like that the first time a while ago and I thought it was sucking it in, only to find out it wasn't.
326WHP 347TQ
Old 08-03-2015, 11:26 PM #19
@gamefreakgc Thanks for the heads up! I'll check it out soon. Secondly, how could I add seafoam if my engine dies immediately after I disconnect the pcv line or brake booster line?
Old 08-04-2015, 12:53 AM #20
Real Name: Jerod
Real Name: Jerod
If someone's on the gas it won't die. Have them rev up the engine a little and then take off the hose. Putting the hose in the bottle is better than pouring it in, if you are going to pour it in it's better to use a brake booster line like the bottle says.
Or just use the Seafoam Spray, it's way easier. Still requires someone on the throttle to keep the throttle valve open though.
326WHP 347TQ
Old 11-23-2021, 05:59 AM #21
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
I was thinking of spraying seafoam through the intake right before the throttle body.
My 4runner has a slight tick, either its from my exhaust manifold (I just put a new manifold in and I feel like I didn't tighten down the egr stud enough) which I just installed, or its something internally.
So I was thinking that trying a seafoam treatment could help throttle response and it produces a lot of white smoke so I could spot an exhaust leak if there is still one.
What do you guys think of a seafoam treatment on a 3rz? Will I ruin my oxygen sensors?
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 11-23-2021, 09:20 AM #22
snydmax's Avatar
snydmax snydmax is offline
Real Name: Matt
snydmax will become famous soon enough
snydmax's Avatar
Real Name: Matt
The process can foil plugs and o2 sensors
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
snydmax is offline   Reply With QuoteReply With Quote
Old 11-23-2021, 08:01 PM #23
Real Name: Jerod
Real Name: Jerod
Potentially. But the smoke show it produces is worth it!!
326WHP 347TQ
1998 , 2.7 , 3rz-fe , 4runner , seafoam
Seafoam'd the 4Runner rtuck1 4th Gen T4Rs 224 02-17-2019 01:26 PM
Seafoam or not to seafoam that is question? CreteDog401 3rd gen T4Rs 16 07-03-2015 04:01 PM
Seafoam my 4runner Atreyus 3rd gen T4Rs 6 05-14-2011 06:47 PM
How do I seafoam my 99 4runner??? maluninja 3rd gen T4Rs 11 03-27-2010 03:15 PM
