09-28-2017, 09:36 AM
#16
Real Name: C8H18 Mike
Originally Posted by gtdan
Just ordered the OEM motor from Amazon (prime too, go figure). Nice writeup, should be a big help this weekend!
Got Link?
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
09-28-2017, 10:13 AM
#17
Real Name: Throws like a girl
Originally Posted by octanejunkie
Got Link?
I'm very curious too....I could only find two listed on Amazon via search for
Mabuchi FC-280PT-22125 with the proper shaft and collar...
One says "Door Lock Motor Replaces Mabuchi/Nichibo Brand" and is 10.99
https://www.amazon.com/Central-Actua...FC-280PT-22125
The other says "Brand new motor manufactured by Mabuchi Model: FC-280PT-22125" and is $44.48, picture shows 'made in China' printed on motor
https://www.amazon.com/Bambuy-Mabuch...FC-280PT-22125
Links appreciated, I'll add the link to my build thread if it proves legit as an option.
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R
I know this is a weird ass question but do you shave your legs or something?
09-30-2017, 12:52 AM
#19
Real Name: Instagram: briansd_97r
Am I the only one with door lock button rattle? That is the best way I can describe it. My door lock pop up button rattles making a low but very annoying squeak. I only stops if I grab onto it.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
09-30-2017, 01:02 AM
#20
Are you sure those are OEM
@ gtdan
? The description says "Door Lock Motor Replaces Mabuchi/Nichibo Brand" but the manufacturer is listed as Mabuchi or Nichibo
I bought this one but haven't installed it yet
http://www.ebay.com/itm/271583579344
There's also this 4 pack that
@ habanero
posted http://www.ebay.com/itm/282430695638
Sent from my Nexus 5X using Tapatalk
09-30-2017, 06:51 AM
#21
@ gtdan
Not 100% sure, but Amazon lists the manufacturer as "Nichibo or Mabuchi". Mabuchi is OEM. I can only attest that it works and looks identical (although every other motor I've seen looks the same too).
I also wanted to order from Amazon so it would come Prime and I could get it done ASAP, since I'm having trouble programming a key fob and moving the lock manually wasn't helping. Plus, I only needed 1 as the driver's door was the only one giving me trouble. Believe me, you won't want to do this for more doors than you have to. ;)
Good luck!
Dan
'02 SR5 Sport 4x4 - Project Rig - ICON Front 2.5 Remote Resi CDCV Coilovers - Rear 2.5 Remote Resi CDCV + OME906 Springs - Addicted Offroad Front Bumper - Rear Diff Breather Mod - Tundra 231mm Brake Upgrade
'11 BMW X5 35d - Daily Driver
09-30-2017, 07:59 AM
#22
Awesome, I'm throwing both the ebay and amazon links in my how-to, thanks octanejunkie and gtdan.
The rear is easier to r/r than the front.
Four years ago I did one of each, the front left and rear right and they've been great ever since.
So far the other two are working fine.
08-04-2018, 04:37 PM
#23
Real Name: Chris
Real Name: Chris
Anyone make a post on how to do the front?
I can’t see to figure out how to get the actuators out of the front doors.
08-04-2018, 04:39 PM
#24
Yeah great write up, was looking for info on this. My 4th gen is starting to have little hiccups from time to time, so this is what I needed.
09-04-2018, 06:53 PM
#25
What is the part number for the plastic clip?
Anybody knows what is the part number and size for the black plastic clip in the attached photo? Where can I buy those in case it is broken.
Thanks,
--stoney
Reason: resize attached photo
09-04-2018, 07:06 PM
#26
trick to disconnect motor power connector
I was trying to use a pocket screw driver to disconnect the power connector to the motor assembly. But even after I inserted the pocket screw driver inside the space, it is still very tight to be disconnected. Any trick here?
Thanks,
--stoney
07-17-2019, 01:01 PM
#27
hello all, first post and i figured it would be better to keep my information contained in this thread as it looks like it hasnt been asked yet.
i just bought a 99 limited last week. once i started driving it, i immediately noticed that the drivers door doesnt unlock when it gets hot. i did a quick search and found this thread.
im not great with electronics, so i was thinking about just buying the whole unit itself:
https://www.rockauto.com/en/moreinfo...57455&jsn=1098
(can be found under body>door lock actuator)
or OEM:
https://www.amazon.com/Genuine-Toyot.../dp/B005VWREZG
is it recommended that i shell out twice the amount for OEM, or will asin suffice?
does anyone know if i swap out the actuator, will this be an issue in the near future? i didnt see anything in the OP that mentions why this happens in the first place? the only thing i can think of is age?
TIA.
99 4runner limited; imperial jade mica
IG: mesooohoppy
07-17-2019, 01:43 PM
#28
or OEM:
TIA.
I just swapped out all 4 motors in the actuator of my son's 2000 a week ago. Cost me 20 bucks and sometime. If you can use a socket, screwdriver and some glue then you can do it. Plenty of threads on here showing how.
Sent from my SM-N960U using Tapatalk
07-17-2019, 02:23 PM
#29
thank you. i am aware what you can do with just the motors (the first post of this thread is very helpful).
in my original post, i state that i am not great with electronics. i would also like to save time by just buying the entire unit. i dont want to buy the unit, just to have it fail in 6-12 months time.
will going the motor route (versus buying the whole unit), yield a longer service life? if so, can you please explain why? thank you.
IG: mesooohoppy
07-17-2019, 11:08 PM
#30
I'm not a electrical person either. It's as simple as popping the cover off the motor, pull old motor out, take spiral brass sleeve off the old one, slide it on the new motors, push new motor back in and glue the cover back on, reinstall the motor part on the locking mechanism, reinstall back in door. An old saying a guy told me one time, "if your 75% smarter than a watermelon you can work on it". This is true, as far as longevity....I have no idea. If you need help, PM and I'll be glad to answer any questions.
