Originally Posted by habanero
It's been so long I had to look back...6 years ago, figuring I'd have to replace them if the repair didn't work out anyway, I used a small screwdriver and a hammer and gently worked my way around and around, careful not to drive it too deep. I had to do two of them, used Mops motors, both are still working great.
Thanks for the tip about the hammer. I have already ordered all 4 new door lock actuators but will experiment with the hammer method on my old ones.
My original factory door lock actuators are aisin. The actuators from online Toyota dealers were around $110-130 each when I checked. I was lucky to find a Toyota passenger side actuator from amazon for $37 prime but the rest of the actuators I bought were aisin which were around 60$ each.
Aisin door lock actuator part numbers:
Front Right: DLT-070
Front Left: DLT-061
Rear Right: DLT-073
Rear Left: DLT-109
Toyota door lock actuator part numbers:
Front Right: 69110-35050
Front Left: 69120-35050
Rear Right: 69130-35060
Rear left: 69140-35060
Another tip I thought I'd share because I didn't really see it mentioned but before removing the actuator, unscrew the plastic door lock knob. It took me a little while to figure out how to remove that part to free up the actuator. I also had a hard time removing the front door handles and was actually easier for me to unclip the rods from the door handle with the handle still in place. The rear door handles were much easier to remove. Don't know why that was the case.
Edit:
The plastic door lock knob only needs to be removed for front doors.
