01-08-2004, 02:05 AM
3rd Gen. Burn Out
Hey guys, my 3rd gen. 4runner has front hydraulic disk brakes and rear is mechanical drum brakes. I have a set of tires on my Runner that are about to be changed to new ones, and ive never "peeled out" or anything and just want to try one. Question is, if i hold the brake (not ebrake) will it work my front AND rear brakes? Or just the front? If it is just the front, then its ok to hold the brake and give it gas right?
Oh and please dont think im some crazy guy behind the wheel or i treat my Runner like garbage.....ive just always wanted to try one.
Anyhow........Id appreciate anyhelp you an give me, Thanks!
99 Toyota 4runner 4wd Limited
-Tv/Dvd/mp3
01-08-2004, 11:30 AM
Your brake pedal will activate all 4 brakes and your rear drums are hydraulic with a mechanical mechanism for the e-brake.
However, it should still be possible to do a small burnout, since your front brakes are more powerful than the rear. Not much much good for your brakes or transmission, but you should be able to get one rear wheel spinning while standing still.
You can also put on the brake hard and hit the gas to get the revs up, then take your foot off the brake. That's often how car mags get the best 0-60 times. I wouldn't recommend doing that with a vehicle you own though.
I probably shouldn't have told you this. Now you'll go and do abusive things.
2000 SR5 4x4
01-08-2004, 04:21 PM
lol Dont worry, i dont abuse my 4runner, most people actually tell me that i care too much for my car. I guess theres no way to do a standstill burnout without the rear brakes being applied while doing so. Or is there?
-Tv/Dvd/mp3
01-09-2004, 03:13 PM
Stand on brake, then start pressin down the gas until the wheel starts to spin or smoke, should be about 2000 or 3000 RPM where the wheel or wheels will start to spin, then just hold it their and burn rubber, after awhile you can just let up on the brake and pull away
Good luck let us know how it works out
12-10-2013, 09:55 PM
If you have an automatic, don't do it too long. Since there's theoretically no air running through the radiator you can permanently damage the transmission by building up an excess of heat. If you have a 5spd, then go for it. But make sure that plume of smoke is indeed from the tires and NOT the clutch. Ask me how I know.
1997 4runner. Sr5. 5speed. 191k.
12-10-2013, 09:59 PM
I tried it once and nothing happened
I obviously have too much traction
12-10-2013, 10:16 PM
This is the oldest thread I have ever seen. Didn't know forum went back to 2004. Anyone know when it started?
12-10-2013, 11:33 PM
Maybe the thread hit 88mph during the burn out and found it's self in the future?
12-11-2013, 12:35 AM
Wait til it rains, find a hill to drive up from a start and stomp on the throttle... Lolol
97' SR5 4X4- elbow delete, ISR, 40W DDM LED headlights, TB gasket mod, coolant bypassed, 14" BAMuffler, poly rack bushings, dirtydeeds custom rear tube bumper with poison spyder shackle mounts, King 2.5 coilovers, BFG AT KO 285/75/16, CBI ditch light brackets, HAZARDOUS LIGHT cubes, light bar, and LED interior lighting.
12-11-2013, 12:53 AM
Real Name: Chris
Real Name: Chris
Holy record breaking thread revival batman! Thread from 9 years ago!
12-11-2013, 01:10 AM
good lord this thread is old.
just get some snow and ice... I've been drifting mine all over the place lol.
'94 SR5 V6, 2" body lift, 4.56 gears, 31x10.50-15, Hella 500's (needs less stock!)
Originally Posted by KidVermicious
I wouldn't be opposed. With another kid on the way, four doors is looking more and more attractive.
12-11-2013, 12:43 PM
Doing a burnout is totally irresponsible. Unless you take video and post it here, then I find it acceptable.
2000 4Runner 4WD - lifted, e-locked, TRD supercharged 5-speed | MY BUILD THREAD
12-11-2013, 01:22 PM
I think trying to do burnouts in a 4Runner is about as smart as these guys.
Car Catches Fire at Tuning Show by Mix939 - Car Videos on StreetFire
You could do what they did - chain it to something so you don't have to hold the brake.
2002 T4R Limited, 191K miles - OME 883 front - LC 7 wrap/2nd gen sway bar links rear - Detroit Truetrac Diff - Cooper A/T3s - Warn M8000 - ARB Bumper - homemade (er, 'custom') rear bumper w/tire & can carrier - BajaRack - Diff Breather Mod - Hayden trans cooler - Yaesu 2M, Cobra CB - Fridge, off-road trailer with Tepui RTT (real expo poser)In Africa they say: "Buy a Land Rover and it will take you anywhere. Buy a Toyota and it will take you there ... and bring you back home." jannikt on wranglerforum.com - I'm guessing he didn't make many friends there with that line.
12-11-2013, 01:57 PM
X2
Originally Posted by Singtoe
What is all this step on the brake noise? All you have to do is step on the gas really hard.
stop teasing all of us!!!!
and
Originally Posted by 98OzarksRunner
this is what will happen if you do a "burnout" with you 4runner!!!!!
2002 4runner Sport Edition-camburg mid travel set up,shrockworks front bumper and lot more!
2002 Tundra limited-Toytec lift, Teflon wheels and 35's
1994 4Runner- 4.88s, Grizzly locker, Old man emu,Surco roof rack and 8 working lights, 204k on the clock!
My build thread- http://www.toyota-4runner.org/3rd-ge...ld-thread.html
