Old 08-20-2015, 03:44 PM #1
HairyMan HairyMan is offline
HairyMan is on a distinguished road
Bilstein Rear Shock Install vs. Stock Install Question
I am finally getting around to installing the rear bilsteins I picked up from a forum member nearly a year ago. Since they are adapted to fit the 3rd gen rear upper mounts, I am not sure which washers/bushings I should use (as compared to a stock installation). See the attached pic of the setup.
I found this thread that outlines the p/n for an em replacement. http://www.toyota-4runner.org/948527-post6.html
Should I use any additional washers and/or bushings, or just bolt em on as-is?
Thoughts?
Bilstein Rear Shock Install vs. Stock Install Question-photo-3-jpg
'97 4Runner Limited
HairyMan is offline   Reply With QuoteReply With Quote
Old 08-20-2015, 03:58 PM #2
snivilous's Avatar
snivilous snivilous is offline
snivilous will become famous soon enough snivilous will become famous soon enough
snivilous's Avatar
Just bolt them on as is, washer on the nut side. Nothing fancy.
snivilous is offline   Reply With QuoteReply With Quote
Old 08-20-2015, 04:03 PM #3
Excellent thats what I was hoping to hear! No wait to install - finally getting around to doing it this weekend.
'97 4Runner Limited
Old 08-20-2015, 05:25 PM #4
Brentif Brentif is offline
Brentif is on a distinguished road
The hard part is getting the nut tight. The socket (24MIL I think) I had didnt have a large enough recess for the bolt portion of the adapters, so I had to grind the socket out. Try not to bash the crap out of your hands!
Brentif is offline   Reply With QuoteReply With Quote
Old 08-20-2015, 05:43 PM #5
Can you elaborate on what you mean exactly? Do you mean the nut was too tall to fit within the socket? What do you mean "had to grind the socket out"?
I know its really tight near the top mount area - Ive been through this once before on an old 4Runner. I plan to just cut the existing shocks out.
'97 4Runner Limited
Old 08-20-2015, 06:46 PM #6
Any specific orientation the shocks should be at the top mount before I toque the nut down?
'97 4Runner Limited
Old 08-20-2015, 07:20 PM #7
I had two main issues:
1: the diameter of the bolt makes it tough to tighten the nut down, as the bolt goes up into the recess of the socket.
2: getting the ratchet and socket off the nut one it was tightened down was a bit of a pain in the ass, ad the adapter bolt was way up in the socket by the time it was tightened down.
I just use a wrench on the top, and a pipe wrench around the old shocks to get them out.
Old 08-21-2015, 09:51 AM #8
snivilous's Avatar
snivilous's Avatar
I would mount the axis of rotation front to back since the axle rotates more when you flex than it swings forward so then the shock would rotate with it's flexing motion.
Remove the spare tire, crawl under the back and sit down, put a box wrench up top, twist the adapter onto the nut until you can't anymore and then torque the nut down.
OEM rear shock install question alms21 Engines / Suspension / Wheels / Tires / Audio / Accessories 18 10-20-2015 11:00 PM
Bilstein 5100 Rear Shock install Problem hrod79 5th gen T4Rs 5 09-09-2014 08:31 PM
Spring/Shock Install Safety Question Paisano 4th Gen T4Rs 9 06-27-2013 03:08 PM
Lift Install Help: Rear shock will not come off!?!?! Left_Coast_T4R96 3rd gen T4Rs 19 10-09-2011 08:12 PM
rear shock install on 1996 4runner Garth 3rd gen T4Rs 19 12-25-2009 02:18 AM
