Poor idle after installing 7th injector
Hello-
Just got done installing URD upgraded full pump, 7th injector and PCU and 2.2 pulley. After doing the fuel pump first drove 4Runner ran as usual, after installing 7th injector and PCU and pulley it will barely idle, I have to rev motor at 1500rpm for it to smooth out, I removed the 2.2 pulley and replace it with stock and same results, poor idle, barely runs, this is a used kit, is it possible the previous owner had a tune to the ECU which is causing the issue? I've checked my hose connections everything appears to be fine, I removed the line off the 7th injector and there was fuel dripping from that, so I assume the 7th injector is getting fuel. I'm stumped here! Maybe I need to locate a cord for the PCU and default it back to stock URD settings?
Thanks for any advice
1999 4-runner, 4wd, K&N Intake, King Coilovers, 34' Nitto Trail Grappler MT's, LC 8 Wraps, 6000k 55w Bi-xenon HID's, 1.5" BL
Future Mod list: Aussie Locker, Possible Re-gear or SC.
