Originally Posted by snivilous
First off I wouldn't pay someone to rebuild the shocks, it takes about a half hour to rebuild a shock on your first try and is insanely simple and there's lots of guides out there--just me, maybe you don't like doing that stuff or rather not but you could save $80.
And second, 5100s are gonna be inferior to the Toytec setup which is inferior to the Fox setup (even if they're old). The main issue you might run into is the valving in the Fox's being off, which if you are willing to rebuild/pay someone is easy to fix, and since they came off a taco I assume they're pretty set already. I would put the Fox's on your rig, and put the Toytecs on your fiancés.
$40 a shock was the rebuild kit. He would walk me through the process and fill then with nitrogen.
I was thinking the fox coilovers would be a better setup vs the toytec setup but am not 100% sure. I also am not a fan of how blue they are. Maybe swap the coils between the 2 and use the better fox shock.
