Old 09-01-2015, 06:50 PM #1
96-Runner 96-Runner is offline
96-Runner is on a distinguished road
#3 misfire and have done most under the sun
replaced injector gaskets
swap injectors
new coil pack swapped that around also
new plugs n wires
im out of options as to what it could be
96 Runner 3.4L 5-Speed 4x4 (no mods yet)
96-Runner is offline   Reply With QuoteReply With Quote
Old 09-01-2015, 07:10 PM #2
kolelt kolelt is offline
kolelt will become famous soon enough kolelt will become famous soon enough
Maybe new coils in general ?
Are the plugs dual grounded ? What brand? What brand wires ? Do you have correct firing order ?
Do a compression test on all cylinders !
Are you loosing any coolant ?
97 3.4 JDM/5 Speed swap/eLocker Swap/ICON CDC all around/+more.....
kolelt is offline   Reply With QuoteReply With Quote
Old 09-01-2015, 11:03 PM #3
i have the napa sparkplug wires so i believe nothing special as far as dual ground.
coolant stays steady no flux.
firin order is matched and nothing has been swapped as i got the misfire 2 stop for a period of time and returned
havent done a compression test have no knock or coolant/oil variance
Old 09-01-2015, 11:09 PM #4
64rat's Avatar
64rat 64rat is offline
64rat is on a distinguished road
64rat's Avatar
A compression test, cooling system pressure check, and a check under the valve cover should tell you whats wrong. Unless its an electrical problem.
64rat is offline   Reply With QuoteReply With Quote
Old 09-01-2015, 11:17 PM #5
what would i be looking for under valve cover?
Old 09-01-2015, 11:40 PM #6
SST221's Avatar
SST221 SST221 is offline
Real Name: Sean
SST221 is on a distinguished road
SST221's Avatar
Real Name: Sean
Get a noid light there cheap, check for signal to injector.
Tundra/5100, 99 talls w/ 1in aluminium spacer, 1.5 all-pros, BFG A/T
SST221 is offline   Reply With QuoteReply With Quote
Old 09-02-2015, 12:52 AM #7
64rat's Avatar
64rat's Avatar
That would be a last resort after ruling out the others. (broken valve spring, bad cam lobe)
The noid light is a good idea.
Old 09-02-2015, 01:17 AM #8
just got new tps in and that has made cel light off. still have ever so slight lag time 2 time but hardly noticeable.
Misfire, with no CEL '99-4Runner 3rd gen T4Rs 16 06-12-2017 07:17 PM
3.4 Cyl misfire wvjeepers 3rd gen T4Rs 8 11-24-2013 04:55 PM
Cylinder one misfire error code without the misfire MJW 3rd gen T4Rs 4 05-03-2012 09:07 AM
Misfire the_dingman Classic T4Rs 3 01-12-2010 05:09 PM
Misfire? Torinate 3rd gen T4Rs 2 03-10-2009 02:09 PM
