Old 09-05-2015, 12:55 AM #1
Asaspades93's Avatar
Asaspades93 Asaspades93 is offline
Real Name: Asa
Asaspades93 is on a distinguished road
Real Name: Asa
80 series rear axle
I'm curious if anyone has swapped an 80 series rear axle into their 3rd gen. A local shop destroyed my housing (and won't own up to it) so I now blow thru inner axle seals every 6 weeks or so and I'm kinda tired of it. I have another 3rd gen housing that would need to be sand blasted due to rust on the outside and inside of it.
I know that the diff is offcentered on the 80 series axle which is my main conceren, or would a custom driveshaft allow it to work fine? All the info I could find was for other land cruisers. I might be batsh*t crazy, but and info would be awesome
96 SR5, Ghetto ISR mod, SCS Stealth 6s, 35x12.5 Toyo MTs, Bilstein 5100s/Eibach coils, B&M Transmission cooler, 1.5 Inch Fat Pat body lift, OME 851s, TJM XGS Gold series LC shocks, Satoshi grill, Rear diff breather, 167 series snorkel, Toytec rear brake line, All Pro apex Front bumper with custom hoops, Custom rear bumper with Ghetto swing out, First Gen roll bar,LED parking lights/turn signals, Hybrid model
Asaspades93 is offline   Reply With QuoteReply With Quote
Old 09-05-2015, 01:09 AM #2
D Farms's Avatar
D Farms D Farms is offline
D Farms is on a distinguished road
D Farms's Avatar
It's not offset all that much, you can run a double double card driveshaft. The link mounts might even work.
'02 Toyota 4Runner SR5
E-Locked | Geared | Mid-Travel | 35s | Armored | 100% Chooched
D Farms is offline   Reply With QuoteReply With Quote
Old 09-05-2015, 01:17 AM #3
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Post up the shop's name and create a sh!tstorm in all of their reviews.
Just source a proper 4Runner housing. It's not worth the time to make an 80 housing work.
Old 09-05-2015, 01:21 AM #4
Real Name: Asa
Real Name: Asa
It was posted all over fb and i think on my original post when i did my axle seal. I've read reviews on other toyota groups about their shop up in fort collins also. So whenever anyone asks if I recommend a shop my first answer is to stay away from johns 4x4
Old 09-05-2015, 02:29 AM #5
white_n_slow's Avatar
white_n_slow white_n_slow is offline
white_n_slow is on a distinguished road
I've heard good things about John's 4x4, but most of those good things were a decade or two ago. They've been around for a long time.
As for the original question, it's a lot of work considering 4runners can be found in just about every junkard across the US of A. Especially in the front range. Why not just get the axle that will bolt up and work as originally intended?
Yes, an 80 axle would probably work, but you will need to strip it down and run it under some leaf springs or build yourself a custom link setup. The links are different sizes, brackets are in different locations, etc. You will need to strip the housing down to bare and start from scratch. Just seems like a lot of unnecessary work.
1984 Toy Longbed 4x4: lifted, locked, incapable of highway speed
1985 FJ60: OME, 33's, Lockright, Rust
1997 4Runner SR5: Rolled , 1999 4runner SR5: V6, 5-speed, e-locker, 285's, SS 1.2
1988 FJ62: TBI 350, 700r4, FF rear, ARB locked F/R, almost no rust!
1996 Lexus LX450: Factory locked front & rear, OME lift, and a salvage title
white_n_slow is offline   Reply With QuoteReply With Quote
Old 09-05-2015, 12:52 PM #6
Real Name: Asa
Real Name: Asa
^ thats the answer I was looking for. I'm off to find a new 4runner axle. I was sent a link to a guy who did put an 80 series axle in the rear, looks pretty badass
1998 4runner build - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-05-2015, 01:27 PM #7
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
This.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 09-05-2015, 04:36 PM #8
mmml4's Avatar
mmml4 mmml4 is offline
mmml4 is on a distinguished road
mmml4's Avatar
It works for me and you don't need a double carden drive shaft. The lower links are almost in the exact same as the stock axle. The uppers are turned at a different angle and the coil perches are spaced wider. It just depends on how much work you want to do. It' a damn good axle though.
99 4runner SR5 3.4 auto, in the rebuild/build process
2wd to 4wd, SAS, 80 series LC axles and transmission
My Build, http://www.toyota-4runner.org/3rd-ge...ild-build.html____________________________________________
"The significant problems we face cannot be solved by the level of thinking that created them" Albert Einstein
mmml4 is offline   Reply With QuoteReply With Quote
Old 09-05-2015, 05:26 PM #9
D Farms's Avatar
D Farms's Avatar
yeah but you have an lc tcase.
Old 09-05-2015, 07:44 PM #10
mmml4's Avatar
mmml4's Avatar
My bad, I didn't think about that.
Old 09-06-2015, 12:20 AM #11
TXRick TXRick is offline
Real Name: Mr. Allen
TXRick is on a distinguished road
Find one with the elocker.
TXRick is offline   Reply With QuoteReply With Quote
Old 09-06-2015, 12:37 AM #12
Real Name: Asa
Real Name: Asa
found a rear axle minus 3rd member at a pull and pay with very little rust. The people who are allowed to move the car hoists don't work weekends so I pulled both axle shafts and will get new bearings pushed int and plan on going back on my day off to get the housing. If I do go sas (hopefully one day) I will consider 80 axles front and rear. Thanks for all the info guys!
Old 09-06-2015, 08:18 AM #13
IBallEngineer's Avatar
IBallEngineer IBallEngineer is offline
IBallEngineer will become famous soon enough IBallEngineer will become famous soon enough
Glad you found an easier way to deal with your problem. I don't want to tell you not to do the SAS, but I would say you are buying trouble going with 80 series axles. And I can tell you why.
1. They are much wider than you need, 3" wider than a 60 series which is already too wide.
2. The rear carrier uses a 9-1/4" ring gear, awesome strong, totally unnecessary for a 3rd gen. So your 3rd member won't work, and you'll be buying gears and lockers. Although it does have rear discs and full floating axles, again it isn't something you need.
3. Offset rear carrier means unless it's a dedicated trail vehicle, you'll have vibrations, and not good ones. Yes you can try swapping in a L/C transfer case, but that again is of NO value since there is no gear availability.
4. No high steer options available off the shelf for the front. I had my knuckles machined flat on top and had steering arms made. I use a hybrid Toyota/1 ton Chevy steering set up. Spent almost $2500 to do that.
5. The money you think you might save, will get spent, there is no cost advantage.
6. Between the OE options and the aftermarket, you can build much more standardized axles that will give you years of trouble free service.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
IBallEngineer is offline   Reply With QuoteReply With Quote
Old 09-06-2015, 11:41 AM #14
Hellfire knuckles would sorta qualify as an off the shelf high steer solution, but they're not cheap!
Old 09-06-2015, 04:17 PM #15
yeah, exactly, where was he in 2005? could have saved me 20 or 30 dollars!
In shipping...
80 series , axle swap , rear axle
Attn: Anyone running OEM Black Tokico 80 Series LC SHOCKS in the rear BigFishAllDay 3rd gen T4Rs 120 03-08-2022 02:26 PM
WTB 3rd Gen Rear Axle - WNY Modern Curmudgeon Want to Buy/Trade 1 09-19-2014 11:45 AM
Rear axle/suspension problem-axle shifts when going on/off the gas Rusty Plum 3rd gen T4Rs 7 09-07-2014 09:46 PM
Rear axle bumpstop to axle clearance? collin 3rd gen T4Rs 1 03-21-2010 12:39 AM
