08-29-2020, 10:56 PM
Help - Adding a heavy duty tow plug
Hey everyone,
I recently just picked up an older horse trailer that has a flat 7 prong cable, a heavy duty plug. I have a 2002 4runner 4x4 with the tow package. When I went to look under the my truck I didn't see any heavy duty cables to hook up to. I may have missed them but I wanted to check in and see if there are even cables under there for me to hook up to or if there is wire harness kit I need to buy to make at new socket to work. any help would be appreciated.
08-29-2020, 11:13 PM
Official Vendor
Official Vendor
Originally Posted by Hood4Runner
Hey everyone,
I had to wire mine in (it was a while ago) - I'll try to get a photo tomorrow for you
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
08-29-2020, 11:29 PM
Thank you!
08-30-2020, 05:24 AM
the 1996-2002 4Runner tow package consisted of the hitch receiver, auxiliary atf cooler, towing controller, and the 4-pin harness. the towing harness comes out at the vent behind the LH side of the bumper. I think the 7-pin became an option in the 2003-current 4Runners.
08-30-2020, 09:42 AM
Sounds like you'll need to add the 7 pole plug and associated missing wires and a Brake controller aswell if the horse trailer has electric brakes.
08-30-2020, 11:17 PM
Official Vendor
Official Vendor
Thank you!
didn't make it to the shop today; bear with me.
keith
eimkeith.com
08-31-2020, 09:01 AM
Real Name: Patrick
Real Name: Patrick
I've never even heard of a flat 7 prong trailer connector. Are you sure about that? It's a thing, but the only trailer connectors I've seen are 4 pin flat or 7 pin round.
08-31-2020, 12:54 PM
Official Vendor
Official Vendor
keith
eimkeith.com
09-03-2020, 02:55 AM
here's what i found
09-03-2020, 04:11 PM
He means the pins are flat. It should be the "standard" RV 7-pin round connector. There is also a 7-pin connector that uses round pins (older style).
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
09-04-2020, 09:04 AM
Real Name: Patrick
Real Name: Patrick
Oooooooooohhhhhhh that makes more sense now.
