Old 09-22-2015, 03:11 PM #16
96-Runner 96-Runner is offline
96-Runner is on a distinguished road
i will when i get 2 a computer phone wont post
96 Runner 3.4L 5-Speed 4x4 (no mods yet)
96-Runner is offline   Reply With QuoteReply With Quote
Old 09-22-2015, 04:04 PM #17
This is the spark plug from cylinder 3
This is the picture of cylinder 3 spark plug
#3 misfire problems-t4r-spark-plug-jpg
Old 09-22-2015, 07:42 PM #18
ShannanC's Avatar
ShannanC ShannanC is offline
Real Name: Shannan
ShannanC is on a distinguished road
ShannanC's Avatar
Real Name: Shannan
Try to take a pic of the coil boot. If the boot goes bad it will not fire correctly. Get a pic inside the hole where the spark plug is if you can. I've had this problem on both of my runners on plug 3 and 5. I've changed boots before to fix it, a coil another time and an injector yet one more time between the two vehicles. Boots are cheap: $15 or so.
99 4runner Limited 2wd - K & N air filter, deck plate mod, ISR mod, 2" Fat Pat's body lift, Bilstein Tundra 5100s and Toytec 620lbs coils in front, LX450 coils and Bilstein Tundra 5100s in rear, extended end-links and panhard drop bracket, Kinati Mud Hog 315/75R16, JDM engine swap, sport hood, ARB front bumper, 199mm Tundra brake upgrade
ShannanC is offline   Reply With QuoteReply With Quote
Old 09-22-2015, 11:50 PM #19
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
Originally Posted by 96-Runner View Post
So know I know what proper cylinder 3 I tried injector noid light test and both were good. Decided pull plug and ran into major problem. There is caked on baked stuff around plug and threads inside head. Cant tell if oil or not. Any ideas?
If you're saying you're using a test light to check the injector, this is all wrong man.
The injector is measured in resistance.
It should be between 12-18ohms, IIRC.
Don't know if I posted the video already, but if not I will tomorrow.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 09-23-2015, 01:13 AM #20
used noid light 2 check circuit and 9v battery on injector.
sorry 4 typos my phone is bad for doin this.
i replaced plug and runs fine 4now and no CEL.
sparkplug boot is clean and new
cant get picture of gunk in the sparkplug tunnel.
going to do compression test when sun is up and will report back
Old 09-23-2015, 08:23 AM #21
Doc2012's Avatar
Doc2012's Avatar
Again, just to reiterate, you CAN NOT JUST USE A LIGHT AND A BATTRY TO TEST THE INJECTORS ACCURATELY.
They have to be tested with an Ohm meter.
Old 09-23-2015, 01:16 PM #22
checked injector usin ohm test and was injector was good. compression test for 1 3 and 5 are
#1 160
#3 130
#5 165
im pretty sure that there isnt suppose b that range of variance between them
ill put the others up in a few
Old 09-23-2015, 02:08 PM #23
#2 175
#4 160
#6 165
Help! Intermittent Misfire Problems dwade 3rd gen T4Rs 18 08-20-2017 09:45 AM
Check engine light , cylinder 5 misfire/having problems! seanxgodfrey 3rd gen T4Rs 7 07-26-2012 05:47 PM
Cylinder one misfire error code without the misfire MJW 3rd gen T4Rs 4 05-03-2012 09:07 AM
Misfire problems sonicstimuli Maintenance/Detailing 1 03-14-2011 02:25 PM
Check Engine Light Problems (O2, Cat, MAF, Misfire) jkruer01 Problems & Warranty Issues 3 08-24-2009 09:48 PM
