Originally Posted by c0mmon
Hi Folks,
Replacing my Transfer case due to a crack (not the most fun).
Either way does anyone have a write up on disconnecting the drive shafts from the transfer case?
I disconnected the 4 bolts on each that connect to it. but getting any wiggle out of that is just not going to happen it seems like.
use a pry bar or the like, or maybe even a hammer. use caution where you hit it, if you choose a hammer, so as not to dent the shaft, or ding the caps.
they are often stuck on there pretty good, but don't really take too much to get them off.
Originally Posted by turbo8
You kind of have to pry it off, watch your head.
this.
you might put ONE bolt back in place, with the nut on loosely, to save you when it pops off.
1985 pickup
: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5
: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited
: stock.
Build Thread YouTube Channel
