09-25-2015, 12:06 AM
acceptable undercarriage for a 3rd gen?
09-25-2015, 12:11 AM
Real Name: Tim
Real Name: Tim
I would steer clear of that one, but then again I'm in Oregon and really don't have rust problems around here. That just looks like a can of worms to me
'99 5-speed, URD short shifter, Tundra Bilstien/881, 5100/891, TT diff drop, SS Panhard Bar, Studt drop links, Projectors, E-Locked, 231 TBU, Highlander
09-25-2015, 12:33 AM
Real Name: Jerod
Real Name: Jerod
Some of those joints in the frame look a little sketchy. A little surface rust doesn't hurt but it's hard to say on the frame if that's starting to flake off.
Rust gives me nightmares.
09-25-2015, 12:48 AM
Me too... Everything sounded great about this 4Runner until I saw these Picts. I don't mind putting in the time to restore some surface rust, but I'd like to avoid a money pit.
Thanks for chiming in fellas.
09-25-2015, 12:51 AM
Real Name: Jordan
Real Name: Jordan
Southwest cars. Arizona, Socal, NV, and NM. We can't even spell "rust" out here.
09-25-2015, 08:06 AM
official vendor
official vendor
Looks fine to me. You really need to check the inside of the frame rails though. The spot around the rear LCA mounts are known to rust. I have more rust on the underside of mine then that does. If you don't have any holes in the frame you'll be fine with a little TLC.
09-25-2015, 08:13 AM
Pretty much the whole south unless you are on the coast.
1989 Toyota 4runner
09-25-2015, 08:51 AM
If it's a midwest runner I would say that that is fine assuming you take a hammer/screwdriver to the frame to look for soft spots.
09-25-2015, 09:21 AM
Real Name: Mitch
Real Name: Mitch
You need pics of the rear control arm mount. That's where it fails. Rust in the places in your pictures don't turn a truck into garbage like a rusted rear control arm does
09-25-2015, 09:59 AM
↑ This ↑
Overall, that T4R's undercarriage looks like it has a little less rust than mine, but I know that my Rear Control Arm mounts are still solid, so I don't worry about it too much (although they are in need of some TLC if I intend on keeping this rig for many more years.) My fuel tank skid plate and rear strap is completely rotted. I need to replace teh starp before the tank falls off, lol.
Other than that, the rust makes it a pain to work on your rig, but shouldn't be a major concern. It just factors into resale/buying value.
In Ontario, you'd be hard pressed to find a 10+ year old vehicle WITHOUT a rusty undercarriage.
1997 4Runner Limited V6 Auto 4x4 w/E-Locker - 184K Miles
OME 881/890 Springs, Tokico TrekMaster GU3535/GE3536 Shocks, 1" Front Diff. Drop, Front Frame Mounted D-Rings
All-Pro 1.25" Hubcentric Wheel Spacers, 265/75R16 ETS Trail Master M/T, B&M 70268 Cooler (bypassed)
2010 Matrix XRS 2.4L 5-Speed - 130K Miles
09-25-2015, 10:40 AM
Really appreciate everyone who is taking the time to chime in on this. Thank you for the collective expertise.
09-25-2015, 03:12 PM
Living in canada, this one does not look bad at all compared to what we have here.
If you oil/grease treat every year, it will really help with the propagation of this already-existing rust.
But yeah, honestly, I've seen much, much worse for a 15 years old vehicle.
1998 4runner SR5
09-25-2015, 03:59 PM
I have seen worse, but I wouldn't call a yay or nay without seeing the rear LCA-to-frame mounts...that always seems to be the worst spot.
1984 Toy Longbed 4x4: lifted, locked, incapable of highway speed
1985 FJ60: OME, 33's, Lockright, Rust
1997 4Runner SR5: Rolled , 1999 4runner SR5: V6, 5-speed, e-locker, 285's, SS 1.2
1988 FJ62: TBI 350, 700r4, FF rear, ARB locked F/R, almost no rust!
1996 Lexus LX450: Factory locked front & rear, OME lift, and a salvage title
09-25-2015, 04:03 PM
My brothers to the north are making me feel better about this rust. I figure I will go see it in person and ensure the inside of the frame has not been compromised and that the lca to frame areas are straight.
09-25-2015, 05:22 PM
bring a smallish metal scraper with you (1.5'' wide), and a flashlight, and a big towel on which you can lie down on the ground. Then you can scrap off the loose rust and all the dirt and see what's still holding underneath those critical places.
1998 4runner SR5
