11-04-2015, 10:29 AM
Real Name: Michael
Real Name: Michael
Alignment Question
I installed energy suspension control arm bushings up front along with billstein 5100s from the Tundra. Now the alignment place keeps realigning it but it just comes right back out of alignment. Does anyone know what's wrong? My tires are going to be ruined soon and I just got them last year. They blamed it on the grease that came with the bushings.
11-04-2015, 10:42 AM
Well for starters, which bushings, lower, upper, or all? And what is it that keeps changing, give me some readings after the alignment, then readings when it goes out. That would help. I doubt greased bushings is the problem.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
11-04-2015, 11:21 AM
Real Name: Michael
Real Name: Michael
I replaced all of them. I can't get exact dimensions. I do know yesterday morning they came completely loose and my tires were all the way as far off as they could be. You could literally see them sitting like this ---> \ /
I believe it's the lower control arms coming back out of alignment. They told me my tie rods were solid.
11-04-2015, 11:41 AM
OK, well yes if they come lose the suspension action will force them toward each other, giving you Positive Camber. I don't see how the bushings rotating around the bolts would move the camber. It's the bolts that are moving in the slot. If they don't know how to fix it, take it somewhere else!
11-04-2015, 11:53 AM
Real Name: Michael
Real Name: Michael
Yeah I'm going to take it to another shop. I've had a few other people tell me to take it somewhere else too. I just was curious if anyone else has had this problem and found out what it is that's wrong. I think they must not be completely torquing down the control arm bolts.
11-04-2015, 12:12 PM
Only way is if the cam bolts are moving. Could be stripped out bolts? I would get second opinion. No way the bushings are causing it.
11-04-2015, 04:46 PM
Real Name: Michael
Real Name: Michael
The other shop said the bolts were totally loose. He didn't align it though because he found that my passenger lower ball joint is bad. Should I go with OEM or a different brand? I'm thinking OEM.
11-04-2015, 04:52 PM
Lower ball joints OEM only. They are a known part to fail and the OEM's are known to last.
11-04-2015, 05:49 PM
Real Name: John
Real Name: John
Replace the LBJs in pairs. Maybe I'm stating the obvious but just want to be sure they just don't do the passenger side. Definitely OEM.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
11-04-2015, 06:46 PM
Real Name: Michael
Real Name: Michael
Why do I need to do both sides? The drivers side has absolutely no play at all.
11-04-2015, 06:47 PM
Because the lower ball joints are a known fail point on these vehicles. I would replace them every 100k miles with OEM parts no madder how they feel. Mine where solid when my tire fell off!!
11-04-2015, 07:09 PM
Because when they fail your 4Runner can end up on it's roof. They're a known failure point, and not a small failure either... You wouldn't have to worry about the alignment then though.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
11-04-2015, 07:35 PM
Yeah I hate it when that happens!
11-04-2015, 08:33 PM
Me too, it can really put a damper on your day.
11-05-2015, 12:04 AM
Real Name: Michael
Real Name: Michael
Seriously? I just googled it and only found a couple people who had ball joint failure on their 3rd gens. Mine have 285k miles on them right now. From what I've heard from several people in my town is that nothing ever goes wrong on these. A mechanic literally told me that in his 42 years of experience this is maybe the third one on a Toyota he's seen go bad.
