Old 11-06-2015, 11:40 AM #1
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
How to: brake booster
Where is the brake booster in a 01-02 located?...
Is there anything to be careful of when removing or installing it?...
My booster goes off every single time I brake!!
I want to replace it.
Do I need a new master cylinder? Or brake booster?
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 11-06-2015, 11:47 AM #2
cashmoney cashmoney is offline
cashmoney is on a distinguished road
Does the pedal get rock hard when you brake or does it go to the floor? Good way to test the booster is to have the car off and then pump the pedal until it gets hard. Keep your foot on the brake pedal and start the car. If it gets soft after you start it then it's not the booster. If it stays hard then it's either the booster or vacuum problem.
1989 Toyota 4runner
cashmoney is offline   Reply With QuoteReply With Quote
Old 11-06-2015, 12:16 PM #3
4Runner4TW's Avatar
4Runner4TW 4Runner4TW is offline
4Runner4TW is on a distinguished road
4Runner4TW's Avatar
My brake booster went out on me two years ago. Really simple to replace. There's 4 bolts that hold the booster on and one pin that connects the booster to the pedal. I did not need to replace the master cylinder.
1999 Highlander Edition, Imperial Jade Mica, Auto with e-locker, OME 906s Rear with Bilstein 5100 shocks, 5100 with OME 880 fronts, Airaid Intake, Custom cargo basket with Quickfists. Lots of mechanical 241,000+ miles
Follow the Adventure on Instagram: http://www.pictaram.com/user/twistingterrian/3486826971
4Runner4TW is offline   Reply With QuoteReply With Quote
Old 11-06-2015, 01:05 PM #4
Illicitdream's Avatar
Illicitdream Illicitdream is offline
Illicitdream is on a distinguished road
If you replace the MC just make sure you bench bleed it before installing.
99 4runner Natural White, 3.4, 240k Miles and still going strong, Lifted 2.5" all around, Diff Drop, 1.5" Wheel spacers, 285/75/16 A/T, Hayden 677 Tranny Cooler, De-Badged, Black Wheels, Deckplate Mod, 8000K HID.
Illicitdream is offline   Reply With QuoteReply With Quote
Old 11-06-2015, 01:39 PM #5
the only time it got really hard and basically almost would not brake even though i was pressing on the peddle as hard as i could is when i was going down a hill for a long period of time braking the while way down... like a steep incline if you were wheeling for example...
besides that it usually just "boosts" or makes noise really after every single brake!!!
the thing that is making noise is a component on this!!!
How to: brake booster-screen-shot-2015-11-06-9-36-50-am-jpg
Build Thread
Old 11-06-2015, 01:40 PM #6
which part is the booster?...
is the reservoir with the brake fluid in it the master cylinder?????
Build Thread
Old 11-06-2015, 02:14 PM #7
Ouch. You've got a hydraulic booster. Little more complicated than vacuum. The part below the reservoir is the booster. But definitely sounds like a booster. Mine is doing the exact same thing.
1989 Toyota 4runner
Old 11-06-2015, 02:21 PM #8
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
Are you leaking any fluid? Sometimes you can get away with replacing the check valve, and sometimes not. If not replace the entire unit and call it good. Your master cylinder is the section with the fluid in it. The booster is the round solenoid on the side. This is the booster.
This is the booster still connected the master cylinder.
MStudt is offline   Reply With QuoteReply With Quote
Brake Booster/ABS Rogue_Runner 4th Gen T4Rs 7 11-24-2017 08:47 AM
WTB: brake booster for a 99 sr5 markgt531 For Sale: T4R Items 2 07-17-2015 10:20 PM
Brake Booster? MtnLlama 3rd gen T4Rs 10 10-16-2014 09:59 PM
Brake booster? smithTR4 3rd gen T4Rs 8 09-02-2013 12:35 PM
Is my Brake Booster bad? tundrayetti Classic T4Rs 7 02-10-2013 08:25 PM
