Old 11-10-2015, 05:29 PM #1
Supermoney Supermoney is offline
Supermoney is on a distinguished road
Can someone help me find the correct bulbs for ECT light and window switch light?
Recently my ECT light on the CLUSTER has burned out it appears, as well as my rear hatch window light that illuminates the button has also burned out.
Does anyone know the correct style bulbs for these two?
2001 Toyota 4Runner SR5 Sport
Imperial Jade Mica
231mm Tundra Brakes
5100 Bilstein / TRD / OME 890 3" Lift
285/75/16 BFG KO2s
Supermoney is offline   Reply With QuoteReply With Quote
Old 11-10-2015, 05:45 PM #2
volkinator volkinator is offline
Real Name: Eric
volkinator will become famous soon enough
Real Name: Eric
WRITE UP: climate control and dash bulbs 2000 limited
This should have everything you need and more, unless you want regular bulbs. Honestly the LED's are super nice
volkinator is offline   Reply With QuoteReply With Quote
Old 11-10-2015, 05:47 PM #3
BamaDrewski BamaDrewski is offline
BamaDrewski will become famous soon enough
The bulb for the ECT light is labeled as "Toshiba V-2" and has a plastic twist on base. I have plenty if you want a couple.
I have a 2000 T4R LTD 4WD and my rig did not come with a light for the rear hatch switch. Are you talking about the switch that lowers and raises the rear window? The switch in the center dash console?
BamaDrewski is offline   Reply With QuoteReply With Quote
Old 11-11-2015, 12:36 AM #4
Yep, I have a 01, so should be the same. Mine was always lit up until recently.
Imperial Jade Mica
231mm Tundra Brakes
285/75/16 BFG KO2s
4WD selector switch light/Rear window light switch replacement Ventil8 4th Gen T4Rs 22 10-09-2020 11:24 PM
Rear window switch light? bpowa 3rd gen T4Rs 11 03-17-2016 12:07 AM
rear window switch light my dime 4th Gen T4Rs 2 08-22-2015 11:39 PM
2014 4runner 4x4 switch and rear window switch doesn't light up? slee05 5th gen T4Rs 5 06-28-2014 05:10 PM
