11-10-2015, 06:58 PM
Switching to 4.10's
2002 4Runner. My truck originally had 4.10's and I am going to switch it back so that it matches the front ratio. What are all the parts that I need for the rear differential? I can get a whole carrier assemble used for $400. Seems like a lot. Wouldn't I only need the ring gear and pinion and maybe bearings too?
11-10-2015, 07:41 PM
what are you switching it from?
are you still stock? tires/lift/armor etc?
yes, you can just swap the 3rd member. its probably the cheapest, and fastest way to do it.
$400 seems a high, especially if its an open diff. ive seen lots of them for $100. I sold a geared/spooled diff for $400...
yes, R&P and bearings, plus a set up kit. then the install. all total would be more than $400.
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
11-10-2015, 07:42 PM
How is your rear regeared but not your front?
2000 Limited. Lifted....finally!
www.OverlandNV.com
11-10-2015, 08:00 PM
I dunno bought the truck an I guess the rear end had been replaced. Have an issue when locking center diff it binds. Feels as if the front and rear are not working together. Trucks at the dealership right now to diagnose the problem. Theyre saying there is a different gear ratio or the front diff needs to be replaced. So I can buy a front diff with 4.10s for $275. So I asked them to verify the rear had 4.10's. They replied with rear has 3.9's so would you want it back to 4.10? Then I looked into getting a used rear diff. They want $375 for a 4.10 rear diff
So yeah maybe they're jerking me around cuz maybe they really haven't worked on the truck yet.
Struck set up is sitting on KO2's 33 x 10.5 x 15, 3in toytec lift and 2in body lift. Truck drives fine in 4wheel drive. But binds when locking center. Trying to figure out where to start.
11-10-2015, 08:09 PM
I'd jump up to 4.30s. I've got 4.10s in mine and it sucks. I couldn't even imagine 3.90s.
1989 Toyota 4runner
11-10-2015, 08:15 PM
Yeah for 33's, try and go as low as possible. Find out what diff gears are in there right now and go from there, However, I doubt the difference between 4.10's and 4.30's will be that noticeable.
11-10-2015, 08:30 PM
Yeah it's really not bad! This is the fastest 3rd gen I've ever driven. So go with the used 3rd member... Right on!
11-10-2015, 08:45 PM
This is the fastest 3rd gen I've ever driven!
There's a phrase you don't see very often.
1989 Toyota 4runner
when it binds, do you mean on the pavement or offroad? also i have the shit 3.90 gears as well, and 35s. truck is fast on the street, but its slow on the highway and can be a pig going over big rocks and stuff offroad, like this.
of course the guys in the land choochers were havin one hell of a time as well with that rock.
'02 Toyota 4Runner SR5
E-Locked | Geared | Mid-Travel | 35s | Armored | 100% Chooched
11-10-2015, 09:21 PM
Yalls definition of fast and mine must be drastically different. My wife's old xterra was faster than my runner.
1989 Toyota 4runner
11-10-2015, 09:41 PM
Real Name: Alex
Real Name: Alex
I've smoked many "supercharged" xterras and fronteirs.
However, my 4Runner is by no means fast.
OP: Buy a used diff on craigslist. You'll simply need to pull out your old on, scrape the gasket off, apply some RTV, and throw it all back together.
A 4.10 rear w/o locker should be dang near free.
2006 Lexus GX 470 Sport- RR Diff Lock, Metal Tech Sliders, RCI Aluminum Skids, Front Runner Slimline II Rack, SCS F5s, 255/80R17 ST Maxx , OME BP-51s, Dirt King UCAs, Metal Tech RR Lower Links
2016 Lexus IS300 F Sport- F-Sport Air Filter RR Racing tuner
11-11-2015, 12:54 AM
You're running 35s on 3.90s????????????
11-11-2015, 02:55 AM
Your right! Not fast But at least enough so I know I won't die... Haha
11-11-2015, 02:56 AM
Very nice... Will post a few pic after its all together
11-12-2015, 12:01 AM
Picked up 3rd member today... Yayaa $350
