Old 11-16-2015, 08:52 AM #1
Seefral Seefral is offline
Seefral is on a distinguished road
Anyone ever try a rear door light installation?
Stock overhead light doesn't light the hitch and electrical coupler. Would be great when hooking up the trailer in the dark.
Seefral is offline   Reply With QuoteReply With Quote
Old 11-16-2015, 10:18 AM #2
habanero's Avatar
habanero habanero is offline
Real Name: Throws like a girl
habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light habanero is a glorious beacon of light
habanero's Avatar
@MStudt has an awesome one...well, two. Would need the hatch open to use it for what you want. I've got a pair of cheap lights on my roof basket. You'd prolly need something a lot closer to the rear of the roof for something like that.
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R View Post
I know this is a weird ass question but do you shave your legs or something?
habanero is offline   Reply With QuoteReply With Quote
Old 11-16-2015, 10:23 AM #3
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
Thanks!
I did this a while ago. You don't have much room to work with on the hatch. I added a couple Eagle Eye 3w LEDs to the back hatch along with a SPST LED rocket. There are two plastic plugs that you can remove from under the panel that will give you enough room to put in the LED's. I can't remember for sure, but I think I had to drill a hole for the rocket switch. I can check this weekend when I pull it apart to do some work. Wiring is pretty simple too. You'll be able to find power in the rear hatch. You can use the power wire going to the rear window. If you can wait until this weekend I'll get you some pictures of what I've done.
Here's it lit up.
MStudt is offline   Reply With QuoteReply With Quote
Old 11-16-2015, 05:48 PM #4
4x4runner2002's Avatar
4x4runner2002 4x4runner2002 is offline
4x4runner2002 is on a distinguished road
I got a strip of LEDs off eBay and wired them into the rear dome light.
4x4runner2002 is offline   Reply With QuoteReply With Quote
Old 11-16-2015, 06:04 PM #5
Ptpdub Ptpdub is offline
Real Name: Peter Ralh
Ptpdub is on a distinguished road
This is a great idea
Ptpdub is offline   Reply With QuoteReply With Quote
Old 11-16-2015, 09:34 PM #6
derpiful's Avatar
derpiful derpiful is offline
Real Name: Hayden
derpiful will become famous soon enough derpiful will become famous soon enough
derpiful's Avatar
Real Name: Hayden
I need to do this... @MStudt how do you think the light output is? I'd think less than the LED strip mentioned above would, but it's hard to tell from the pictures.
derpiful is offline   Reply With QuoteReply With Quote
Old 11-16-2015, 09:44 PM #7
99 sr5 highlander's Avatar
99 sr5 highlander 99 sr5 highlander is offline
Real Name: Chris
99 sr5 highlander is on a distinguished road
Real Name: Chris
I have the same LEDs as @MStudt used. I used 6 in the rear door wired up to the rear dome light. Light output is awesome and comes in very handy when camping.
Blurry picture of the light output. I also used two of the same lights on the side of the rack.
My 1999 highlander edition, front and rear lockers and a bunch of other stuff build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
99 sr5 highlander is offline   Reply With QuoteReply With Quote
Old 11-16-2015, 10:04 PM #8
concordcarlos concordcarlos is offline
Real Name: Carlos
concordcarlos is on a distinguished road
Real Name: Carlos
Strip of "waterproof" cool white leds from ebay. Ended up moving the strip down to the lowest point of the tail gate since these were hitting the weather stripping and letting in moisture.
Anyone ever try a rear door light installation?-tailgate-light-1-jpg  Anyone ever try a rear door light installation?-tailgate-light-2-jpg
concordcarlos is offline   Reply With QuoteReply With Quote
Old 11-17-2015, 07:53 AM #9
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
A strip will give you more output. I just didn't want to deal with having it fall off. Two of the led's that I have are plenty bright for anything that I'd ever use them for.
Old 11-17-2015, 01:24 PM #10
Bandit Runner's Avatar
Bandit Runner Bandit Runner is offline
Bandit Runner is a jewel in the rough Bandit Runner is a jewel in the rough Bandit Runner is a jewel in the rough
I used 3 of these rock lights in my hatch.
From my build thread:
I decided to mount them to the inside of the rear hatch to provide more light when the hatch is open. I wired them to the stock rear interior light, so they would come on when the hatch was opened.
This was in my garage which was completely dark except for the hatch lights.
I cut square openings in the plastic so that the lights would sit flush in the panel. All the wires are run behind the plastic panel for a clean install.
Bandit Runner, 2021 TRD Off Road Premium
Build Thread: https://www.toyota-4runner.org/5th-g...ild-2-0-a.html
Bandit Runner is offline   Reply With QuoteReply With Quote
Old 11-18-2015, 08:42 AM #11
Thanks!
Terrific ideas. Thanks!
Rear door panel installation tip GrantK 5th gen T4Rs 15 12-03-2022 07:01 PM
Rear Door Light Issue blubill 3rd gen T4Rs 2 06-06-2014 09:23 PM
Rear Hatch Light Switch??? On/Off/Door STRRAYNGE 3rd gen T4Rs 4 06-17-2012 12:09 AM
My Rear door shows open in dashboard light Leviyid Problems & Warranty Issues 2 11-06-2010 11:55 PM
Rear Dome Light not working on Door setting Impala 3rd gen T4Rs 7 12-23-2004 10:45 AM
