Old 11-17-2015, 10:38 PM #1
fblainen11 fblainen11 is offline
fblainen11 is on a distinguished road
97 Shocks and struts replacement question
I have a 97 that has KYB Gasajust shocks and struts. I hate them. The ride is exceptionally hard and uncomfortable over Louisiana interstate.
My question is for OEM rear shocks there is only one part number for rear shocks. However, the front struts have base (15"), SR5 (16"), and Limited (16") options. The ones I believe I need (SR5) cost $60 more per strut. Can I use the limited strut? What is the difference? I'd prefer to just go with the limiteds if they offer a softer ride. Any insight?
fblainen11 is offline   Reply With QuoteReply With Quote
Old 11-17-2015, 10:49 PM #2
jman11788's Avatar
jman11788 jman11788 is offline
jman11788 is on a distinguished road
jman11788's Avatar
The Limiteds and SR5 are the same shock. PN #48531-80693
2000 Limited 4wd Supercharged with E-Locker
jman11788 is offline   Reply With QuoteReply With Quote
Old 11-17-2015, 11:06 PM #3
I'm getting PN 4851039436 for non limited 16"
And PN 4851039585 for limiteds.
Old 11-17-2015, 11:09 PM #4
I'm talking about front struts...not rear shocks. Rears only have one part number. It is the front that have different numbers.
Old 11-19-2015, 11:39 AM #5
Anyone else have any input on differences between sr5 and Limited front struts?
Old 11-19-2015, 01:33 PM #6
jkoni426 jkoni426 is offline
Real Name: Joe
jkoni426 is on a distinguished road
Real Name: Joe
That's strange you find the ride harsh, they're supposed to be stock replacements. I have them and the ride feels stock, the red monomax are supposed to be harsh.
'99 T4R SR5 V6 4WD Imperial Jade Mica | 199mm TBU
jkoni426 is offline   Reply With QuoteReply With Quote
Old 11-19-2015, 01:34 PM #7
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Total speculation, but it seems to me that SR5's tend to sit a little higher/differently than Limiteds. I've only seem limited and base models ever sag, not so much with SR5's.
Then again, it just might be the fender flares that throw me off.
Try calling a Toyota dealership and see what they say.
326WHP 347TQ
Old 11-19-2015, 01:38 PM #8
KaliKid KaliKid is offline
Real Name: Alex
KaliKid is on a distinguished road
Real Name: Alex
Unless your buying the 99 tall coils they are all going to be the same. SR5, Limited they will both fit your 4runner they will both give the same amount of ride height.
If you are replacing why not go aftermarket for a better ride? Just a suggestion but OEM is going to be just as expensive as some Bilsteins.
New Project - 4th Gen V8 4Runner
SOLD - 02' 4Runner, SAS, Dana 60 with matching Sterling 10.5, Chevy 63's, TG 4" springs, 17" Toyo MT 37's.
KaliKid is offline   Reply With QuoteReply With Quote
Old 11-19-2015, 01:42 PM #9
Real Name: Jerod
Real Name: Jerod
He has aftermarket ones on there currently and doesn't like them. The rear OEM shocks are dirt cheap, you can get them for about $35 each. It's the struts that are pricey, more like $120-$150 each.
I have KYB Gas-a-Just shocks as well and I don't mind them at all. They are a little stiffer than OEM but in my opinion are better off-road the OEM since that little bit of stiffness gives more stability. Everyone is different though in what they like.
326WHP 347TQ
Old 11-19-2015, 01:48 PM #10
Real Name: Alex
Real Name: Alex
[QUOTE=gamefreakgc;2187268]He has aftermarket ones on there currently and doesn't like them.
I guess I should be more specific, ANYTHING AFTERMARKET EXCEPT FOR KYB. You get what you pay for sure you can get some OEM shocks for $35 but is it really worth pulling everything off to install those when you could spend a little more $, just as much time and have an overall better ride? Thats for the OP to decide.
Old 11-19-2015, 02:04 PM #11
I'm not really looking for any lift. I am rarely off-road (I use my 87 Honda 3Wheeler for hunting). Good to know. I will call the dealer and ask about ride height difference. My wifes 2000 limited has oem everything and the ride is much better on highway.
I've thought about doing OEM rear and bilstein 5100s up front or 5100s all around, I do worry that the ride will be too stiff over terrible Louisiana roads if I use Bilsteins.
Also, if it is okay to do Bilsteins in front and OEM rears, should I worry about the front sitting higher than the rear?
Old 11-19-2015, 02:23 PM #12
Real Name: Alex
Real Name: Alex
You are replacing the shocks, the coils are what would give you "lift". The only reason you would have a ride height difference is if you went with an adjustable perch strut assembly up front and adjusted it up to provide lift. After thinking about this more and more I think you should just buy the OEM shocks and be done with it. You will be very happy and dont need to worry about what size travel you need to order for stock height, etc. Bolt n go my friend.
Old 11-19-2015, 02:37 PM #13
dallison dallison is offline
dallison is on a distinguished road
I can't believe that we have had our 01 sport and i never found this place before today.
Anyway, i have the kyb shocks also with new springs and i like the firmer ride over the bouncing that we were getting with 170k old ones.
dallison is offline   Reply With QuoteReply With Quote
Old 11-19-2015, 03:04 PM #14
I don't mind the firm ride on smooth roads. However, last year I drove my 4runner from Louisiana to Kentucky hauling a trailer and the worst patch of interstate or highway I drove was a 2 mile stretch between Sulphur and Lake Charles Louisiana....the very drive I make daily on I-10 to get from home to work. The KYBs are nice on smooth road, but the patch of interstate is downright bone jarring on a daily basis. I've got to get something softer.
Old 11-19-2015, 03:18 PM #15
sawguy sawguy is offline
sawguy is on a distinguished road
I just recently replaced the front struts on my Limited and SR5 with "quick struts" from Detroit Axle. I don't off road much and the ride is nice. They were about $120 for a pair. We'll see how they hold up.
sawguy is offline   Reply With QuoteReply With Quote
Shocks and struts question hec983 3rd gen T4Rs 6 12-20-2013 03:04 PM
97' 4Runner Shocks/Struts question Tyler_True 3rd gen T4Rs 0 12-07-2012 02:40 PM
2004 4runner struts/shocks question brennanjr General Discussions 2 07-28-2012 11:04 AM
Another shocks and struts (and springs?) question piperoo 3rd gen T4Rs 4 11-28-2011 02:59 PM
Shocks/Struts replacement vegimate Maintenance/Detailing 0 04-15-2006 01:42 PM
