Old 11-20-2015, 06:51 PM #1
VolcanoT4R's Avatar
VolcanoT4R VolcanoT4R is offline
Real Name: Britt
VolcanoT4R is on a distinguished road
VolcanoT4R's Avatar
Real Name: Britt
HVAC blower motor not coming on...what else can I check??
2001 T4R SR5
229K
No recent mods or maintenance that may have affected performance
The other day I noticed my HVAC fan wasn't working. Here is what I have checked...
Heater fuse (50A) checked...has continuity-->works
Heater relay checked...works
blower motor connected directly to battery...works
HVAC control swapped with two different controls (working last I checked)...inconclusive
Heater blower resistor (HBR) checked per fsm...results below ("o" is ohms)
Connection | per FSM | Original HBR | Pick-n-pull HBR
1-4 | 2.2+/-0.1o | 3.7o | 3.5o
1-3 | 1.2+/-0.2o | 2.8o | 2.4o
1-2 | 1.8+/-0.2o | 3.4o | 2.9o
Looks like my pick-n-pull HBR might also be a dud, so I'll be ordering one. Should I go OEM or is aftermarket okay here?
What else can I check? Aside from troubleshooting the wire harness (which didn't appear to be corroded or anything), the FSM doesn't
Should I try to put a resistor on the HBR connector to simulate the HBR and see if I can get the fan to come on?
Thanks in advance!
'01 SR5 4x4--219K--Purchased in February 2014--99 Talls--Bilstein 4600s--5stars wrapped with 265/75/16 Duratracs
'07 SR5 2WD--68K--Purchased in October 2014--Leaving it stock
VolcanoT4R is offline   Reply With QuoteReply With Quote
Old 11-20-2015, 10:22 PM #2
BamaDrewski BamaDrewski is offline
BamaDrewski will become famous soon enough
Originally Posted by VolcanoT4R View Post
2001 T4R SR5
229K
Thanks in advance!
I am pretty sure there is a blower control module mounted to the evaporator core behind the glove compartment. You have to pull the core case out, open it up (clean it while you are in there) and check the motor control. (it looks like a big white chunk of white ceramic). When I did my total AC job, I found the unit/controller was cracked in several pieces. This might help. Just a suggestion.
BamaDrewski is offline   Reply With QuoteReply With Quote
Old 11-20-2015, 11:00 PM #3
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Manual or digital control? Very different systems.
My Backyard Frame Swap
Old 11-21-2015, 02:12 AM #4
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Sounds like what most folks call the 'blower resistor'. In my '91 Toyota it was bare wire coils mounted on a plinth---and it burned out about every six years. In my '97 it is a much heavier duty ceramic block style resistor.
pluton is offline   Reply With QuoteReply With Quote
Old 11-21-2015, 07:49 AM #5
VolcanoT4R's Avatar
Real Name: Britt
VolcanoT4R's Avatar
Real Name: Britt
Manual system
Old 11-21-2015, 02:41 PM #6
TheDurk's Avatar
TheDurk's Avatar
Manual system
First, it's not your HBR if fan won't run on HIGH. That completely bypasses the HBR.
Sounds like it's the control switch, if you have ruled out the relay.
The switch has to do two things:
Energize the relay coil, and,
Send 12V+ to the HBR (LO or MED) or directly to the motor (HIGH).
Test protocol for the control switch is under Service Hints in the EWD linked below:
http://tacoma.site40.net/4Runner_96-...i/057acman.pdf.
Did you test the relay in place by grounding the yellow/red wire at the blower switch? Did you check if the white/black wire at Pin 1 of the blower switch is a good ground? Try connecting the motor to the battery with switch on HIGH but do just ground and then just battery positive. That will determine if problem is on relay side or switch side.
Old 11-21-2015, 09:55 PM #7
Pedrojr80's Avatar
Pedrojr80 Pedrojr80 is offline
Pedrojr80 is on a distinguished road
Pedrojr80's Avatar
HVAC blower motor not coming on...what else can I check??-image-jpgHere is the wiring diagrm so maybe it can help you pin point the problem
Pedrojr80 is offline   Reply With QuoteReply With Quote
Old 11-22-2015, 09:21 AM #8
VolcanoT4R's Avatar
Real Name: Britt
VolcanoT4R's Avatar
Real Name: Britt
Awesome, thanks! I'll get on that today.
Old 11-22-2015, 09:22 AM #9
VolcanoT4R's Avatar
Real Name: Britt
VolcanoT4R's Avatar
Real Name: Britt
Awesome, I really appreciate that. It should help me narrow down the source of my problem. Thanks!!
Old 11-22-2015, 09:26 AM #10
VolcanoT4R's Avatar
Real Name: Britt
VolcanoT4R's Avatar
Real Name: Britt
I tested the relay by pulling it out and energizing the pins (can't remember which one's at the moment) to make sure I heard it "click". Will test using your method and post results. Thanks again.
Old 11-22-2015, 03:02 PM #11
TheDurk's Avatar
TheDurk's Avatar
Yeah, my way will test the relay, as well as the socket, the power supply, and the wiring up to relay contact point. Also, a 'çlick' is by no means a sure good indicator. It can click without passing current. You need to see zero resistance on the contacts with a meter when you test off the truck.
See the way Toyota says to do it:
http://tacoma.site40.net/4Runner_96-...c/hmr/insp.pdf
What I would really like is for you to ground that yellow/red wire with key on and switch on HIGH. Then check for 12V+ at both ends of the A/C fuse. Then do the same without grounding the yellow/red wire. That will tell us a lot. Do that before you test the switch. You may not have to.
There is a better switch test protocol at Item 9 here:
http://tacoma.site40.net/4Runner_96-...manua/insp.pdf
Old 11-22-2015, 04:04 PM #12
VolcanoT4R's Avatar
Real Name: Britt
VolcanoT4R's Avatar
Real Name: Britt
Confused by what exactly you're asking me to do here. I understand grounding the yellow/red wire from the connector (with the controller removed), but not sure what I am checking. Should I just be listening to the heater relay to find out whether or not it is coming on?
Ground at pin 1 of the Blower SW connector is good (checked continuity from pin 1 to ground)
If I understand this correctly, you want me to:
a) "just do ground" essentially bypassing the AC control while letting the truck control POSITIVE voltage. Is this correct? If so, what I did was turn truck on, turn AC control to HIGH, connect connector B6 (blue-red, pin #2) to the POSITIVE terminal on the blower motor and connect the NEGATIVE terminal on the blower motor directly to the NEGATIVE terminal of the battery. Results, fan did not come on.
b) "just battery positive" essentially bypassing the heater relay while letting the AC control (set to HIGH) connect to ground. Is this correct? If so, what I did was turn the AC control to high, connect the NEGATIVE side of the blower motor connector (B6, pin #1: blue/black) to the NEGATIVE on the blower motor and connected the POSITIVE terminal of the blower motor directly to the POSITIVE side of the battery. Results, fan DID come on.
So, appears my issue is on the relay side of the switch. Guess I'll bench test the relay again.
Old 11-22-2015, 04:07 PM #13
VolcanoT4R's Avatar
Real Name: Britt
VolcanoT4R's Avatar
Real Name: Britt
Tested switch per page AC-97 and all checked out.
Thanks for the explanation regarding testing the relay. Doing that now.
Old 11-22-2015, 04:17 PM #14
VolcanoT4R's Avatar
Real Name: Britt
VolcanoT4R's Avatar
Real Name: Britt
Not sure I have enough experience to know how to do what you are asking me to do here. The way I was planning on grounding the yellow/red wire was to pull the connector out and connect pin 8 on the connector directly to ground. Not sure how to ground the wire if I have the switch connected and set to HIGH. Would jumping pin #1 and pin #4 simulate the switch being set to high?
If not, can you explain how to ground the yellow/red wire with the switch connected? That has me perplexed. Maybe, go in through the back of the connector?
Sorry for the stupid question.
Thanks again for all of your help!
Old 11-22-2015, 04:27 PM #15
OffRoadGuy's Avatar
OffRoadGuy OffRoadGuy is offline
OffRoadGuy is on a distinguished road
OffRoadGuy's Avatar
Damn.. Its great to see you guys come out helping with all these diagrams. I'm like saving each each one for whenever I need to do some trouble shooting. Thanks!
OffRoadGuy is offline   Reply With QuoteReply With Quote
Hvac blower won't shut off drdolittlerwc 3rd gen T4Rs 5 04-01-2018 01:51 PM
hvac blower motor speeds during acceleration blain_gatterdam 3rd gen T4Rs 7 03-22-2013 03:20 PM
Rat got in blower motor. greenmonkey 4th Gen T4Rs 4 10-24-2012 09:21 PM
AC002-07 HVAC Blower Motor Ice Build-Up Bossman TSB 3 08-18-2011 09:52 PM
HVAC Blower cheda 3rd gen T4Rs 0 06-15-2011 02:34 PM
