Real Name: Kyle Seal
Removing U Joint (easy) Question
Rear U Joint went bad, took out the driveshaft to replace it, well upon observing the u joint, it seems there are no lock rings? I do not see any to remove, is this normal?
I also have new Moog ones, that have lock rings, will I not need the lock rings? Seems stupid to not have the or even have a slot for them.
In short, my question is does my driveshaft have retaining clips/rings with the rear u joint?
I have the drive shaft that has two u joints in the front. Double chamfer or something I think it is.
1998 Toyota 4Runner 4wd v6.
1998 4R v6 4x4. One owner. New engine. Good body, has some secrets though.
