12-01-2015, 01:40 AM
Real Name: Zach
Real Name: Zach
Did I screw up?
In efforts of clearing 285s, I started pounding away at the pinch weld, and cutting some of the plastic in the wheel well.
I might have got carried away, and cut off a bit much of the plastic, AND tried to flatten the weld a bit higher up as well. I noticed a small split along the line. Is this gonna be a problem? Worried about possible water leakage.....
Look ok? Should I seal it somehow? Does yours look this way?
Can anyone chime in on this?
My Build Thread
1999 Highlander Edition w/ Factory E-Locker: Alarm/remote start, FN 5 star wheels, 285/75/16 Duratracs, King 2.4 Ext Travel C/Os, LC shocks/8 wraps, 1" Diff drop, Airaid Intake, Dual B&M 70264's, Satoshi grille, 01 Tails, shackles, Rear diff breather extension, Blue wire mod,Taco whip antenna, Window tint, Bi-xenon Morimoto Mini Stage III projectors, 231mm Tundra Brake Upgrade, Interior LEDs.
12-01-2015, 01:53 AM
Real Name: Hayden
Real Name: Hayden
Mine is currently the same way, a small gap on both sides. Haven't noticed any problems (but haven't kept a super close eye on it), but do plan on patching it up. I would recommend sealing it up if you're happy with your trimming, no harm can really be done... JB Weld would probably do it well, or if you have access, a welder would probably be even better!
12-01-2015, 10:55 AM
Mine is missing the plastics on both sides, no issues in over 100k miles with lots of mudding!
12-01-2015, 10:57 AM
Real Name: Kevin
Real Name: Kevin
I don't think there's anything to worry about there. Keep smashing until it's flat.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
12-01-2015, 05:38 PM
Real Name: Chris
Real Name: Chris
That happened to mine from my tires rubbing before i got a lift and i havent noticed anything weird with it.
1999 4wd 5 speed sr5 - King 2.5 coilovers - Total Chaos uca's - Toytec Superflex rear springs - E locker
12-01-2015, 07:53 PM
Real Name: Instagram: briansd_97r
I did the same thing then filled the gap with foam and painted it black.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
12-01-2015, 07:56 PM
meh. did I screw up?
'02 Toyota 4Runner SR5
E-Locked | Geared | Mid-Travel | 35s | Armored | 100% Chooched
12-02-2015, 01:40 AM
Real Name: Zach
Real Name: Zach
Wait, WTF......
Haha damn!!!
My Build Thread
12-02-2015, 01:41 AM
Real Name: Zach
Real Name: Zach
Ok, I don't feel quite as bad. Happen to remember what kind of foam you used?
My Build Thread
12-02-2015, 01:44 AM
Real Name: Connor
Real Name: Connor
I don't have one of those.
Untitled by Connor Rhoades, on Flickr
But seriously, hit it hard, fill it with sealant, paint over it.
1996 Toyota 4Runner 4x4 w/ 5 speed- Lifted, Locked,Painted,Armored
Build: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
Originally Posted by invisible4Runner
Highlander = minivan, purses, soccer practice
4Runner = testosterone, steak, dirt
12-02-2015, 02:52 AM
honestly you dont need to weld it, a lot of the body is sealed with silicone from the factory or simply folded over. get a sheet of aluminum cut it to shape with hand shears and rtv the piece in. oh yeah you havent even cut anything nevermind...
heres what it looks like after i welded it closed. the body is enclosed by the sheet metal, the plastic is simply there to act as a sort of mud flap for the metal thats underneath and to hide it as well.
12-02-2015, 09:23 AM
Real Name: Throws like a girl
The pinch weld actually has openings at intervals all the way along it. I'd thought of it as pretty air and water tight before, but it isn't.
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R
I know this is a weird ass question but do you shave your legs or something?
12-02-2015, 12:40 PM
Real Name: Jerod
Real Name: Jerod
Home depot sells the stuff, I always keep a bottle of it around the house. It's used for filling gaps around vents & pipes to insulate your house but I tend to use it for just about everything. It's super messy though if you're not careful though.
http://www.homedepot.com/p/GREAT-STU...2848/100003351
12-02-2015, 02:50 PM
Real Name: Zach
Real Name: Zach
LOL I remember seeing this pic of yours. Damn! You ended up welding up a plate on it right?
My Build Thread
12-02-2015, 02:52 PM
Real Name: Zach
Real Name: Zach
Originally Posted by gamefreakgc
Thanks Jerod, I tried some cheap gasket stuff from ACE, but it was sort of water-y. I'm gonna pick some of this stuff up tonight. Much appreciated.
My Build Thread
