12-10-2015, 03:32 AM
Real Name: Michael
Real Name: Michael
Best flexing
So many lift threads, and I'm sorry for my contribution. Here's my wants though:
I want only around 2 to at most 2.25ish" of lift all around, but I want it to flex as well as possible. I know, that's so little lift to be able to get great flex, but I DD my truck and I like it to stay reasonably capable and still comfortable (physically and economically) for every day and loooong distance road tripping with my family while hitting trails once we get where we're going. So I don't want to change the mechanics/geometries up so much that stuff starts becoming far less reliable.
I've read that quite a few people have not been stoked on the 2" OME setup because it's pretty stiff/harsh and provides no increased flex. However, it seems like once you start going the 5100's and TRD Tundra coils with LC or Superflex route, you get into that 3-5" lift range that I'm just not wanting to get into (too much lift for my taste and I don't want cv replacement to become a hobby).
So....~2.25" lift, good flex, good ride conditions, maintaining reasonable geometry and fantastic reliability.
Any suggestions and pics?
Once lift is done, I really want to do an electric locker then just use the truck. I was originally going to do the bumpers, sliders, full underbelly protection, but I realistically think that my off road use just doesn't add up to utilizing all of that. I don't hardcore crawl, I just like to access isolated locations that other people have a hard time getting to.
2000 Desert Dune Limited 4x4
12-10-2015, 04:20 AM
Real Name: Matt McKenna
I'm not a 4Runner guru, so forgive me on not knowing what gen can use the LC coils...
If they make it for your year, I would take a look at the iron man foam cell pro. People are loving it over on the fj forum. If I could go back, I would get that on my fj, not my Toytec lift. Planning it for my dads 5th gen. I believe they are fully adjustable, but guys normally run at about 2.5 inch lift.
I believe another option is just using bilstiens to lift the front a bit, and a small spacer or slightly longer springs in the back.
Not sure if this helps at all..
Cheers,
Matt
12-10-2015, 05:05 AM
flex on our trucks is mostly about having long enough shocks in the rear, and soft enough springs in the front. id recommend getting some tundra 5100s for the front with stock springs. the tundra 5100s have more travel than the tacoma 5100s so make sure to get those instead. Use fj or 5th gen 4runner coils for the rear. in the rear use any standard fzj80 rear shock of your choice. also get a front sway bar disconnect, and extended brake line for the rear. once you get all that stuff the next thing would be to replace all suspension bushings and steering components and ball joints. I highly recommend using energy suspension poly bushings where you can, they are cheap and make the truck ride smoothly with no binding. then your truck will be in good shape.
'02 Toyota 4Runner SR5
E-Locked | Geared | Mid-Travel | 35s | Armored | 100% Chooched
12-10-2015, 09:50 AM
Check my signature. I love my suspension.
1989 Toyota 4runner
12-10-2015, 10:06 AM
Real Name: Kevin
Real Name: Kevin
Big tires and sway bars are the enemy of proper stuffage. Shove some spacers in in there if you don't want OME (but it's not nearly as bad as everyone says it is). Trim the bumpstops, yank the front swaybar, leave the back one in but disconnect it when you hit dirt. As long as you stay 265s or smaller, this setup will give you real decent uptravel on all four corners with no rubbing.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
12-10-2015, 10:11 AM
Agreed on disconnecting the sway bars but I'd buy a set of disconnects for front and rear. I'm driving with no front sway bar and it's definitely a lot more sway-y. Works great on the rocks though.
1989 Toyota 4runner
12-10-2015, 01:40 PM
if you get longer links the rear sway bar can stay connected all the time, there is no good solution for quick disconnecting it anyways. plus it forces the front to flex.
12-10-2015, 02:16 PM
He wants only 2" lift.
I agree with others saying stock front coils and 5100's with FJ rears and a longer shock. This will give most flex with the amount of lift you want. Again those rear FJ's wont flex that much.
I run ome 881's up front and they flex just like any other spring all the way to the bump stop and droop just fine.
12-10-2015, 02:39 PM
How do you get 2" of lift with the stock coils?
12-10-2015, 02:50 PM
Adjustable billy shocks. They will raise the ride height a good 2".
12-10-2015, 02:58 PM
Real Name: Justin
Real Name: Justin
Just when I was about to take my shirt off and start flexing for the camera for this thread I realized that u were referring to suspension flex. Some will get a kick out of my avatar
12-10-2015, 03:39 PM
D Farms, that is some pretty amazing front flex.
The rear end is pretty well designed for flex--even stock it will outperform most other vehicles on the trail. Just get a spring on the softer side, make sure your shocks aren't limiting travel, and get a panhard bar drop/lift bracket to make sure nothing is contacting anything it shouldn't.
I also like the idea of stock front coils lifted via bilstein 5100 adjustable perch.
1984 Toy Longbed 4x4: lifted, locked, incapable of highway speed
1985 FJ60: OME, 33's, Lockright, Rust
1997 4Runner SR5: Rolled , 1999 4runner SR5: V6, 5-speed, e-locker, 285's, SS 1.2
1988 FJ62: TBI 350, 700r4, FF rear, ARB locked F/R, almost no rust!
1996 Lexus LX450: Factory locked front & rear, OME lift, and a salvage title
12-10-2015, 03:40 PM
I used Tacoma 5100's and OME 881's on the front of mine and it's great. First perch. OME 891's and 5100's out back. A little too much rake, but after I give it a chance to settle out a bit I can move it up a perch. Ride is awesome.
NEW BUILD** 1996 SR5, IRON MAN foam cell Lift, TransCooler, Calvary Blue
OLD BUILD** 1997 SR5, OME 881/891 with 5100's. New radiator, Hayden trans cooler, trans temp gauge, LBj's, ITRE's, OTRE's, all fluids changed, 265/ 75 BFG's, ISR mod, deckplate mod, Ebay uniball UCA's, "Big 3" mod.
Build thread: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
12-10-2015, 04:10 PM
If you want some serious flex go with LC coils in the rear, but that's gonna give you more than 2" of lift. That's all I thought I wanted also at first, but I couldn't be happier now that I went with 3" upfront and 4" in the back.
I wouldn't recommend trimming your bumpstops either, you'll end up over compressing a shock and blowing it out. If you stay with stock length shocks leave the stock ones as is, and if you go with longer travel shocks you need to lower your bumpstops so you don't over compress your shocks and damage them.
I extended my sway bar links about one inch and they don't limit my flex at all, no need for disconnects in the rear. I'm sure the front is limited by the sway bar though.
2008 Toyota 4Runner Limited 4x4 - Salsa Red, DD, Mostly Stock, 89k miles
2001 Toyota 4Runner SR5 4x4 - Not Stock, Lifted, Armored, 291k miles
1987 Toyota Supra N/A - Stock, 2nd Owner, 92k miles
12-10-2015, 05:44 PM
for reference, I have trimmed bump stops up front by over an inch, but i also have a progressive body lift thats 0" in the rear and 3" up front. the front is also tubbed to fit 35s with the extended up travel. no front sway bar. tundra 5100s with stock coils on the 4th perch. in the rear i have 8.5 wrap lc coils, monroe lc shocks, panhard lift, 2nd gen rear links on my sway bar, extended trailblazer bump stops.
if you do run fj coils get some coil retainers in case they fall out, they are short.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
