12-12-2015, 07:44 PM
Inconsistent Starting
I've been having an inconsistent starting experience with my '99 with 184k miles.
It had new plugs put in about 2k miles ago and I just replaced the plug wires with NGKs.
I cleaned the TB and MAF a couple weeks ago with no changes in measured fuel mileage. It runs fine with no issues and gets 18-20mpg consistently.
Sometimes it starts immediately on the first crank, sometimes it doesn't unless I hold the key over longer than I like - about 3 seconds. It may be me.
Are there any other components involved in this process that are potential culprits? Cam sensor, O2 sensor? Before the plug wires were changed, if I turned the key all the way off and tried again it would start better. May be my imagination but that seems to help.
Any ideas?
Bstrom of Powell, TN
2003 Tundra | 1999 4Runner Limited 4WD | 2011 Mazda CX-7 Sport
12-12-2015, 07:52 PM
Fuel Filter.
2015 T4R TRD Pro in super white, Morimoto 4300K HID kit, Auer Engineering / Toyota LED DRL/Fogs 2-in-1's, TRD drop in air filter, WeatherTech front and back liners.
2002 T4R SR5 4WD Onyx Black Sport Edition w/Leather. Gone but not forgotten.
12-13-2015, 07:45 PM
Originally Posted by stir_fry_boy
Fuel Filter.
Forgot to mention. I've already changed it.
My battery is 4 years 9 months old and about 100 amps below spec. Starts and runs fine routinely, just seems slightly sluggish. Would that much of a drop be enough to inhibit snappy starting?
12-13-2015, 07:59 PM
Real Name: Mr. Allen
Battery cable tight and clean?
12-13-2015, 08:24 PM
Yup...this vehicle is in great shape, just seems weak in the start department. I've eliminated all the maintenance items as causes, I believe.
On the battery, what is the lowest amp reading before swapping out supposed to be? We got any battery experts here?
12-13-2015, 08:45 PM
Real Name: John
Real Name: John
Any ideas?
IAC or MAF IMHO
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
12-13-2015, 10:25 PM
Originally Posted by Singtoe
Your fuel pump is bad.
Might want to do a fuel pressure check before he goes diving in on parts.
☆Floor Mats
12-14-2015, 12:09 AM
Even if the vehicle runs without issues and gives correct fuel mileage? What would be wrong with it? Low pressure or something?
It idles perfectly at ~600rpm with AC off and ~750 rpm with it on. That should rule out the MAF too.
This may be more imaginary than anything else. My 20 year old Miata starts instantly with no hesitation. This 4R has high mileage so maybe I shouldn't expect perfect behavior.
I might just go ahead and replace the battery since it will need to be in a little while. I put one of those beastly 7-year Bosch models in my F-150 and it made a difference. Cranking amps might be low enough on the 4R to prevent a clean start.
12-14-2015, 02:42 AM
Real Name: Kurt
Real Name: Kurt
Could it not be all the recent questions regarding this where most seem to make it sound like the contacts need replacing. I have the same issue lately and thinking about doing this version. Not even taking the who start out just the front so i can replace the contacts and plunger. I hear it fixes most of the problems. worth a shot and prices around $40 i think for the 3 pience at the local steeler ship
2001 SR5, AOR Front/CBI Rear Bumper, King Coilovers - LC 7 Wrap/5125 Billies, 265/75/16 BFG K02 on FJ TE wheels, Stubbs sliders, 1.25 Spidertrax, B&M Transmission cooler, 231mm TBU, RAT skid, Lightforce Blitz 240 HID
12-14-2015, 06:21 AM
Any ideas?
I have had the same problem with mine ever since I have owned it. Nothingi have tried has fixed it. I just deal with it cause it doesn't change the performance of my truck.
1999 Toyota 4runner Limited 3.4L, ARB Front Bumper, KC 6in Aplo Trail Lights, ISR Mod, K&N Air Filter, Midland CB, Diamond K400-3/8C Mount, 4ft Firestick, Sonora Steel 1.2 w/2.5" Radflo coilovers, BFG KO2 285/75/16
12-14-2015, 08:00 AM
First issue would be fuel delivery. If your fuel pressure is good after it warms up and has been running for a while the next thing I would do is upgrade your ground. I know everyone just rolls their eyes at this but it is important that your secondary grounds are working well. My theory is this , when starting which is your biggest draw by far on both the positive and the ground, if your ground is maxed out, all the functions for the engine to start(ecu sensors etc) will be weaker than they would while running. You can test this out by bump starting if you have a manual and then stopping and crank start it. If it fires as soon as you drop the clutch but cranks for a while when you use the starter you should upgrade your ground. Autos are harder to test but if it takes 5 second of cranking to start, crank it for 3 and then let off the key. If it fires as soon as you let off the key you have a weak ground. This is just my opinion but I upgraded my ground on my tacoma and it cut the cranking time down to normal. I followed a thread on ttora and even if you don't do the big three a ground upgrade will help.
12-14-2015, 09:54 AM
Banned
Banned
Fuel pump is a reasonable place to start.
The pump itself may be fine but there's a check valve on the inlet, and if that goes bad it allows fuel to drain back out of the line and into the tank. Then when you try to start it the pump has to fill the line up before you get the proper amount of fuel pressure at the rail, and it can cause long cranks.
I'd put a gauge on it that you can see from inside and keep an eye on the pressure at start up. If that's the problem you'll likely be able to see a difference in pressure between a normal start and a long one.
12-14-2015, 09:58 AM
Long shot is starter contacts. Cheaper than a fuel pump and easier to replace.
1989 Toyota 4runner
