Originally Posted by I_bRAD
There is a flex section attached to the steering knuckle, but the actual connection to the caliper is a hard line- so you'll need to disconnect that to change the caliper. If it's frozen in there, the factory pre-bent section is pretty cheap to avoid the hassle of making your own (I think it's about 10 bucks)
Gotcha, I assumed it was hardline > flex line > caliper.
I just did Bilstein's up front recently but didn't inspect my brake line's. I initially said he could encounter problems with the fitting between flex line and hardline. Doesn't seem as though that's necessary, so the hardest portion to someone inexperienced is bleeding the brakes, is it not?
I haven't discovered this for myself yet. My bad for the ignorance on the details.
