Originally Posted by Bad Luck
Did you bleed/purge the cooling system of air after replacing the radiator cap and thermostat? OEM radiator cap?
Good news guys. I fixed it!
I'm not sure exactly what fixed it, but I did 3 things.
Replaced radiator cap, which alone did not fix it. However, the old cap did have a piece missing from the bottom. Whether or not this was preventing a good seal, I am not sure.
Secondly, I replaced the thermostat. While doing so, I drained the coolant out of the radiator. I refilled with 1 gallon of the Asian red stuff from advanced auto. This, too, did not fix it. At least not right away.
So then I figured maybe the 1 gallon wasn't enough to top off the radiator. So I bought another gallon and used about 3/4 of it to top the radiator to the very top. I'd drive a little bit, loosen the cap to burp it, drive a little bit, loosen cap to burp it, repeat while driving around my neighborhood.
While doing this I had heat full blast and turned off overdrive.
Now everything is running cool. As good as new. Needle is stuck just below halfway point.
I don't think I did any permanent damage because the 2-3 times it hit the red line I shut the engine down immediately.
I was so happy that I went ahead and replaced the power steering belt and AC belt.
Thank you to everyone who helped me. And thanks to the wealth of knowledge in this forum which helped me diagnose and go step by step trying the cheaper solutions first. And thank GOD I don't have to try to get in there and replace a water pump or something more serious and expensive.
