01-28-2016, 02:09 PM
Previous Owner Horror Stories - Let's Hear 'em
So most of us by now I'm assuming have bought their 4Runners used. Let's hear your horror stories and the strange issues you found when after you bought it!
I'll start. My previous owner was the KING of all shitty handymen. The "fixes" and problems he made while he owned it are unbelievable. I'll start in chronological order of the issues I found. So right off the bat, the ABS light is on. So I look into it further, checking all the fuses and whatnot. Everything checks out till i get under the vehicle. I discover that this guy disabled his ABS by CUTTING the wires to the front brakes. Rather than pulling the fuse, he permanently disabled it. Next up, I realize that the blower motor isnt working! And neither is the rear defroster. So I check out the blower motor to see what's going on, and I find mysterious electrical components hanging down under the glove box. This leads me to discover that this guy had a leaky evaporator in the cooling unit. So instead of removing it like a normal human being, he BROKE open the cooling unit and tore it out. In order to prevent ridiculous airflow coming in, he insulating taped it up and left the electrical components stuff up there. Now onto the blower issue. I take apart the whole dash in the middle and find an unplugged wire. I look back there and manage to cram my big hands in and plug it back in. Voila! A/C light comes on, blower motor blows, defroster works. So for reasons unknown, this guy disabled his entire HVAC system. Winter comes along and my heat doesn't work. Further investigation shows that he managed to break the plastic clip holding the wire for the hot/cold dial. After a while of driving it, I start to realize that there's a burning plastic smell. So I investigate and find that part of the electrical components he stuffed up behind the glove was the resistor for the blower motor!! Melting various plastic pieces behind the dash! Now the final issue I found today was the airbox. The PO broke all the bolts holding the airbox in place. I removed the airbox to clean the MAF and found a big hole in the back of the airbox behind the filter! The PO forgot to remove the last bolt and broke a hole in the back of it. I am astounded at this man and his "fixes". So pathetic. A little bit of patience, research, and elbow grease could have easily fixed all of this the right way!
Well thanks for listening, let's hear some of your stories!
01-28-2016, 02:53 PM
Real Name: Connor
Real Name: Connor
Holy cow, makes me really appreciate the fact that the previous owner of my 'Runner actually took care of her instead of being a dumbass.
My dad's 03 Excursion with the 7.3L on the other hand... that's a different story.
'99 4Runner - '00 Yamaha WR400F - '03 Suzuki SV650
I hope you got a really good price on that truck.
My previous owner was a smoker. It's a good thing that I gut and clean the interior of every vehicle I buy used. Now there is zero smell, just a few cigarette burns in inconspicuous parts of the carpet to remind me of this 4Runner's smoky past.
01-28-2016, 03:13 PM
Can I ask OP why didn't you test some of these things out BEFORE buying the 4runner? As T4R2014 stated I hope you got a good price on it.
If the truck has had so many problems I wonder what it looks like under the valve cover.
I have walked away from many so called good buys before after discovering the myriad of potential and obvious problems for each of them. Check one's emotions at the door.
01-28-2016, 03:20 PM
Real Name: Eric
Real Name: Eric
Wow... just wow. Mine just needed a good vacuum and scrub down. And the locks didn't work, but that's from that pesky wire loom going to the rear hatch. Still baffles me that people will sell a filthy car without even trying to make it look nice. Oh, also found $8 in change. Paid for the first car wash!
Emptied the vacuum 3 times from the dog hair, and scrubbed everything including behind the dash. No more funky smells, or sticky surfaces. Now I just need to figure out the AC... everything comes on, and it'll work if I refill it, but it loses it's charge really quickly. So I've got a leak somewhere... yuck.
2000 Limited | e-locker | 33's | Skids/Sliders | TRD SC | Sold
2007 Limited | V8 | RCI | OME 884/895e | 255/75r17 | JBA's
01-28-2016, 03:28 PM
First time buying a vehicle and I was a little nervous. I did research on things I knew to look for but I didn't think to look under the glove box and stuff like that! It's hard to do a good once over on a vehicle in a short amount of time! Also, I did pay a good price. $2200 CAD which is like $1500 USD.
A lot of weird issues but she is running great and I wouldn't trade it for anything!
01-28-2016, 03:31 PM
For my current 4runner, previous owner was a mom w/ 2 kids. she drove it for >100k miles w/o any maintenance and service other than oil change. I had to update a lot of it by the time it came to me.
first owner on my current 4runner was great. He took the car to dealer for all services. However, he had a large dog that tore up the interior. Looking for a interior swap later on.
As for my first 4runner, I bought it right before it blew head gasket first month in. I suspect the previous owner was aware of it before she sold it to me. She was very eager to sell for less than the original asking price.
1993 Honda Accord EX | 5 speed
2000 T4R Limited | TRD SC w/ URD 7th injector and factory rear diff lock
1994 T4R SR5 | 5 Speed 4WD SOLD
2007 Subaru STi | Stage 2
01-28-2016, 04:14 PM
Real Name: John
Real Name: John
I don't know if it was the PO but after about 3 months of owning my previous Runner, I found the frame rust hole by the muffler had been filled in with that foam crack filler stuff you buy at home depot. It was then cut to form and bondo putied over then painted. Couldn't even tell it was rusted. Looked pretty good. Someone was on a mission.
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
01-28-2016, 04:20 PM
Real Name: Samuel
Real Name: Samuel
The previous owner of my sport was the original owner and had it dealer maintained and then had it professionally detailed before selling it to me. Not to mention brand new tires too! Plus a hot daughter.... I can't complain on that one. Although I did find a French fry that the detailers missed it was delicious. The 99 was just dirty and I didn't really care. The 98 was smoked in and I'm in the process of taking everything out and cleaning it. The 99 limited is pretty clean inside its the outside that's the problem. All the sellers I've dealt with have been pretty up front and honest maybe cuz I threw a wad of cash at them.
Edit: I just remembered that my 02 that was wrecked had a Celine Dion cd in it. I bought it from a guy. I should've taken his mancard
2001 Sport Edition 4WD, IJM, Auto, DD
1999 SR5 4WD, Millennium Silver Metallic, 5 speed, E-locker, Trail Rig
1998 SR5 4WD Custom bodywork from hitting a median. Beater truck.
1999 Limited 4WD No longer a vehicle. Now it's in parts and stored away.
01-28-2016, 06:31 PM
Holy shit man, that's quite the 4runner lineup you got there!
01-28-2016, 06:36 PM
Real Name: Samuel
Real Name: Samuel
Thanks! I'm a junk collector/hoarder. I get it from my dad who still has more vehicles than me. I have 5 total(there's a jeep in there) he's got 7
01-28-2016, 06:42 PM
since my dad was the original owner he had this mechanic who would work on the truck, when i did my body lift the intake ripped apart. i found that it had been previously mended with electrical tape. I also found an unfused 12v cable running from the battery to the tow hitch connector that was wrapped around the frame, it was frayed in one spot, I think uhaul installed it. I found a bunch of subflower seeds under the center console, but those were from my dads long road trips. other than that nothing strange at all. I also learned that my dad didnt even know about the center diff locker, which is funny to me because I specifically remember going to sedona as a kid and my dad high centered the truck and we had to tip it over this rock to get it going, the center diff locker would have helped haha. granted it was on the stock size 28s with the running boards and everything.
'02 Toyota 4Runner SR5
E-Locked | Geared | Mid-Travel | 35s | Armored | 100% Chooched
01-28-2016, 06:48 PM
I get the feeling that I'm the PO that people talk about in threads like this :o
I have kept in contact with the new owners of several of my vehicles and they aren't always appreciative of my modifications (like welding shock tabs in place of the stock pin hole for the rear shocks). One of my PO's sent me a text like "who did this to the shock mount? I had to grind all that metal off to bolt in a tab." I was like you could have just bolted your shocks to the tab I welded on and saved yourself the time and the cost of the bolt-on tab. Also had a different new owner contact me to inquire about an aftermarket full float axle, an ADD switch I wired up, etc.
I also seem to buy a lot of vehicles with random aftermarket switches that don't do anything :o I can forgive PO's for stuff like that. The only thing that really grosses me out is sticky messes, food, etc. One of my FJ60's came loaded to the gills with Malamute hair.
1984 Toy Longbed 4x4: lifted, locked, incapable of highway speed
1985 FJ60: OME, 33's, Lockright, Rust
1997 4Runner SR5: Rolled , 1999 4runner SR5: V6, 5-speed, e-locker, 285's, SS 1.2
1988 FJ62: TBI 350, 700r4, FF rear, ARB locked F/R, almost no rust!
1996 Lexus LX450: Factory locked front & rear, OME lift, and a salvage title
01-28-2016, 09:08 PM
Real Name: Woody
Real Name: Woody
My '99 limited was pretty clean and well maintained, never had a problem with her until she got totaled.
My current '00 SR5 wasn't bad, but had old oil in it, bald tires, about 1/5 of the coolant it should've had, and the radio was broken. Plus there was a weird noise in the drive train somewhere. Luckily an oil change, coolant, new tires, water pump, and new timing belt solved my issues. No problems now. *Knock on wood*
- "Judy" '99 Millenium Silver 4WD Ltd. w/ 186K miles KIA
- "Judy II" '00 Desert Dune Pearl 4WD SR5 w/ 169K miles SOLD
- "Judy III" '01 Imperial Jade Mica 4WD Sport w/ 199K miles
- 3" Toytec BOSS lift | 1" Toytec BL | 1" Toytec diff drop | 285/75R16 on FJ TRD wheels | 1.25" Spidertrax | Tundra brake upgrade | Midland CB | Shrockworks front winch bumper w/ Warn 9500 | Shrockworks rock sliders | CBI rear bumper with tire swing away | KC ditch lights+reverse lights | custom rear cargo drawers/sleeping area -
01-28-2016, 09:21 PM
There are too many stories from back in the day, of hack repair attempts I fixed, after the owners tried to "fix" a problem.
A good one was a failed u-joint on a customers truck. The guy went to a Hardware Store, and bought bolts, washers, nuts, and Bailing wire. The two bolts took the place of the u-joint, and the bailing wire was used to lash the bolts together...
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
