01-30-2016, 03:31 PM
E-locker to non-locker rear
My 97 rear e-locker is leaking pretty bad. I have found a non-e-locker with 4.10s that is fully rebuilt for $150. Is it a simple process to swap? Is it dumb to get rid of the e-locker?
2017 TRD Off-Road Premium. Magnetic Grey. Dual Odyssey battery setup. Falken Wildpeak AT3W. Diode Dynamics SS3. Rigid Dually Spotties.
01-30-2016, 03:54 PM
Shame you're all the way across the country... I'd swap with you
NEW BUILD** 1996 SR5, IRON MAN foam cell Lift, TransCooler, Calvary Blue
OLD BUILD** 1997 SR5, OME 881/891 with 5100's. New radiator, Hayden trans cooler, trans temp gauge, LBj's, ITRE's, OTRE's, all fluids changed, 265/ 75 BFG's, ISR mod, deckplate mod, Ebay uniball UCA's, "Big 3" mod.
Build thread: http://www.toyota-4runner.org/3rd-ge...ld-thread.html
01-30-2016, 03:56 PM
I'm sure most will agree with me here. Do not get rid of your locker. A fully rebuilt third for $150 is cheap. The gears are standard. ECGS wants $600 plus core but, they're the best you can get. Who did the rebuild? What brand gears are in there? See what the cost would be to rebuild the locker and park your 4runner for a while. OEM lockers are hard to come by. If you decide you don't want it, please let me know. I hope you keep it.
EDIT: You're only an hour and half from me. I'll drive up and pick it up from you if you decide to do the swap.
2001 Imperial Jade Gold Letter Sport Package - Original Owner
01-30-2016, 04:00 PM
Real Name: Kevin
Real Name: Kevin
If you pull the entire housing, yes. If you need to put the open third in an elocker housing, it'll take fab work. Yes, it's dumb to get rid of the elocker.
What exactly is leaking?
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
01-30-2016, 04:21 PM
I replaced the putter seals a out three months ago. I'm assuming it's the bearings.
01-30-2016, 04:23 PM
I'm pretty sure it's the bearings on the axle that are leaking. You know how hard it really is to fix these? I know requires a machine shop and all.
I wanna keep my locker. Trust me.
01-30-2016, 04:34 PM
Real Name: Kevin
Real Name: Kevin
You're leaking gear oil into your drums? It's almost definitely your wheel bearings, and replacing your third won't fix it, and you don't need a machine shop to replace your bearings. Even if you don't have access to a press and a welder to make an SST, you can cut the old retainers and ABS rings, and once they're off the wheel bearing comes out with a hammer and a drift. Buy new ABS rings and retainers and drive them on with a piece of thick wall 2x2 square tube you can get at any steel supplier or scrapyard. There's nothing hard or scary about it.
01-30-2016, 04:36 PM
Give Adin a call at NW team Yota (360)953-8676. He's in the shop now. They're right down the road from you here in Vancouver.
If he can't help you, call ECGS on Monday and ask for a quote: 919-672-2705
01-30-2016, 04:39 PM
^^^^^Yea, HUGE difference between axle bearings and your locker.
01-30-2016, 04:45 PM
This post is so ironic because I'm getting ready to pull the trigger on fully assembled thirds from ECGS for my 2001 with 4.88 gears and considering adding the ARB lockers to both the front and rear. Cha ching $$$$$$$$ I would have the best of both worlds with A TRAC and Lockers.
01-30-2016, 11:57 PM
Does your existing axle have 4.10s also?
