02-03-2016, 11:47 PM
4Runner Camping Mods
I'm wondering who else likes to sleep in their 4Runner when they're out camping. What are some of the mods that you've done to make it a more enjoyable experience? So far, I have built a storage platform for the rear, based on RamRod's thread ( Link to his pictures)
Here's a picture of mine, before I stained it
I tried to build magnetic screen coverings for the side and rear windows, but the magnets I bought were not very good. They were too small, and kept sticking to each other, and it was also difficult to sew the trim around the window screens. So I gave up on that project, and was looking at some commercial alternatives such as this one:
Amazon Link
Anyone use one of these before? I'd like to make one for the rear window, but can't figure out how to deal with the damn rear wiper being in the way..
Anyone install any type of insulation in the rear panels, to make it warmer while you're sleeping in the cold? I'm wondering if this would be a winter-only thing, and if I'd have to remove it in the summer to avoid baking like an oven. Thoughts?
I found a thread on YotaTech where a guy was selling an old '87 4Runner, and in his post he said
Sleeping area has been fully insulated with Reflectix liner to keep things cool/warm.
The stuff seems pretty thin, and I definitely think it would help cover the window glass and keep the warmth from escaping there. I don't know if it'd be suitable for behind the rear cargo area panels. I don't feel like pulling all the panels and installing the Reflectix in the winter, only to remove it all come spring time.
You guys do any inverter mods / LED lighting / fans for the rear or anything of that nature?
'98 4Runner: 3.4, 5-speed, 4x4, E-Locker, Tundra TRD Front Coils, OME 890's, (5100's front and rear), ARB Bumper with Warn M8000, 4xInnovations sliders, 199mm Tundra Brakes, Tacoma Whip Antenna, Uniden 520XL CB radio, '99+ Center Console, ~167,000 miles
02-04-2016, 12:40 AM
Update:
Reflectix is best used for situations where you have a lot of radiant heat entering the vehicle (summer-time). You can put it in the window, and it will effectively reflect the heat back out, preventing it from warming up the vehicle.
You can also use it behind paneling, but you have to make sure to leave at least a 1/2" air gap between the exterior wall of your vehicle, and the Reflectix. Otherwise the "R" value is super-low and it doesn't reflect the heat out as well.
If you're mainly camping in cold weather, then you want to insulate, in order the keep the heat in. In order to do this, you'd use a product called PolyIso (van-dwellers are using it inside their vans, non-toxic). This, however, would also keep the heat inside the vehicle longer during hot, summer days. You really have to judge what conditions you're going to be using the vehicle for.
The site also said that if you have an A/C setup in your vehicle (to run while sleeping during the summer), then you CAN insulate using PolyIso, because it will help keep the A/C inside and the heat out. With no A/C, the PolyIso is basically working against you.
As I understand, you can also use a combination of the two, but you'd have to have the outer sheet metal, then the 1/2" air gap, then the Reflectix, then the PolyIso.
Hope this can help someone else, because I had no idea about any of this until I started reading on CheapRVDweller. Pretty cool blog if any of you guys are into that stuff.
02-04-2016, 01:03 AM
Originally Posted by tx_shooter
That's really a good idea! Might have to weld some of those up.. Steve sure has found an awesome niche with all of his 4Runner products.
02-04-2016, 01:06 AM
Real Name: Alex
Real Name: Alex
Is that price for real?? $20 + shipping for him to drill holes in my plastic? lol
2006 Lexus GX 470 Sport- RR Diff Lock, Metal Tech Sliders, RCI Aluminum Skids, Front Runner Slimline II Rack, SCS F5s, 255/80R17 ST Maxx , OME BP-51s, Dirt King UCAs, Metal Tech RR Lower Links
2016 Lexus IS300 F Sport- F-Sport Air Filter RR Racing tuner
02-04-2016, 01:08 AM
People will pay it. Also, another one of my favorites is the emergency brake cable extension bracket. I had a 1/2" wide piece of scrap, drilled two holes, and bought one more 12mm bolt...voila.
But people will pay it. Like I said, he's got a good niche
02-04-2016, 01:27 AM
Real Name: Chris
Real Name: Chris
for a window screen someone had mentioned using rain gutter screen panels or something that worked perfect. Maybe someone can post a link to that. Search sucks through Tapatalk.
BTW I like the idea of this thread.
AzBub Build2000 Toyota 4Runner Highlander, 4x4, E Locker. 4:30 gears. TRD Taco springs on Tundra 5100s. FJ80 8 wraps/Monroe economy rear lift.
02-04-2016, 02:04 AM
Real Name: Bryson Abel
1999 Toyota 4Runner SR5/Limited build
here is the box i built, the door is magnetic and it hold my two subs and all of my tools and other miscellaneous things.
02-04-2016, 04:59 AM
Real Name: Alex
Real Name: Alex
My 4 dollar window screen!
I have a set that I have used quite a few times. I love them =D.
Painted black w/ spray paint for cool points.
02-04-2016, 05:37 AM
lol also the 75 for 4 bolts you can make from stuff at the hardware store.
'02 Toyota 4Runner SR5
E-Locked | Geared | Mid-Travel | 35s | Armored | 100% Chooched
02-04-2016, 09:53 AM
official vendor
official vendor
No fancy TIG welding though.
02-04-2016, 10:13 AM
Real Name: Cross
Real Name: Cross
Wow those bolts are a great idea. Although I refuse to buy anything from SS mainly because of stuff like this. $75 for maybe $7 in materials? Not to mention they offer drilling 1.5" holes in "just the right spot" for $20 + shipping. That's disgusting.
"My ex said it was either her or the 4Runner"
2002 Sport Edition
Smittybilt Defender Rack/4 Hella 4000s/ 285/75/16 Toyo AT2/16" Level 8 MK6 -10 offset/Tundra front springs/OME 891 rear springs/Bilstein 5100s Front and 5125s Rear/2" Fat Pat Body Lift/CBI Front Bumper/Smittybilt X20 Winch/22" Led Lightbar/5" Led Pods
02-04-2016, 10:18 AM
I used the reflective insulation in between my headliner and roof for noise dampening. It has worked pretty well. Not sure how well it is insulating because I don't camp in severe conditions. Most of my camping is beach trips.
2020 TRD Off-Road Premium
ShrockWorks sliders
Southern Style Offroad slimline hybrid front bumper
OpenRoad4WD 13000lb winch
Gobi Roof rack and ladder
02-04-2016, 11:07 AM
Those wing bolts are great! I always just brought along my ratchet to pull the seats out, but that's definitely more convenient Might make some for the lexus!
1984 Toy Longbed 4x4: lifted, locked, incapable of highway speed
1985 FJ60: OME, 33's, Lockright, Rust
1997 4Runner SR5: Rolled , 1999 4runner SR5: V6, 5-speed, e-locker, 285's, SS 1.2
1988 FJ62: TBI 350, 700r4, FF rear, ARB locked F/R, almost no rust!
1996 Lexus LX450: Factory locked front & rear, OME lift, and a salvage title
02-04-2016, 11:33 AM
Think about it this way-
There are far more guys out there that can't do stuff now. I bet 1/2 the dudes that say $20 is too much(not on this forum, this forum has a lot of skilled and smart members) will go to HD or Lowes and buy 1 1/2" bit. When they get it home it won't fit in their 3/8" chuck. So they will go back and swap it for something else. Maybe a paddle bit, or a uni bit. They will not layout the holes correctly and the hole will be off. So they will 'waller' it out to fit. It will look like a$$. And they will crack the plastic part after taking it off and putting it back on the 7 times it takes them to fit it up and get the 'waller' part in the right spot.
I would not pay $20 + shipping, but some people will, and a lot more should, lol.
'99 Limited, 4WD, elocker
