Originally Posted by LittleCaesar
It could be the neutral safety switch, or at least check the wiring to it if you were able to crank it in N for some time.
Fuel, compression, spark. One or more is missing.
Concerning the ECU I have seen 2 Honda Civic ECUs that have had fried resistors in the last four months.
This whole neutral safety switch thing really confuses me.
If its job is to let you *start* while in P or N ONLY... when it is *broken* wouldn't you think you *can't* start in P or N?
You and others are saying it could be bad because you can start in N... isn't that it's job?
Or is it that OP *can't* start in P, but can in N, so it is serving 50% of its function and thus could have some bad wiring? Or when bad, it can go haywire and just kill the starter no matter what gear?
