Old 03-04-2016, 09:58 PM #1
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
What brake bleed sequence do you use?
The FSM says FR, FL, RR, RL. Most people say furthest to closest so RR, RL, FR, FL. But from what I understand the front and rear and basically separate systems, there are 2 fluid compartment presumably for safety, so it shouldn't really make a difference between front or rear first?
repo is offline   Reply With QuoteReply With Quote
Old 03-04-2016, 10:18 PM #2
silver4est silver4est is offline
silver4est is on a distinguished road
I've always heard RR RL FR FL, farthest from master cylinder to closest and that's the way I've always done it.
silver4est is offline   Reply With QuoteReply With Quote
Old 03-04-2016, 10:24 PM #3
JudeThaddeus JudeThaddeus is offline
JudeThaddeus is on a distinguished road
Actually, it does matter. I tried 4 times bleeding my brakes after fixing a bad rear wheel bearing using the farthest to closest method. Every time my breaks still sucked. I then read an excerpt from the FSM that you start with the FR and move to the FL. After that, you move to the rear. All of this is done with the vehicle running and after bleeding off the power booster by pumping the brakes with the engine off before bleeding.
Know what, my brakes feel great after having crappy brakes. I actually have confidence that I'll stop while breaking now.
JudeThaddeus is offline   Reply With QuoteReply With Quote
Old 03-04-2016, 11:24 PM #4
99Runnr 99Runnr is offline
99Runnr has a little shameless behaviour in the past
Tundra brake upgrade is semi-notorious for causing soft brake pedals. Myself included after the first bleeding. I do the standard furthest to closest method, with a twist since then.
I have my helper, push the pedal ONCE. Don't pump them up. Push, hold, open, close, push, open, close, repeat. I go through the 4 bleeders like this twice.
Just did it with a dry system, after replacing all soft lines with SS lines. Had it back to a solid pedal in 15 minutes. Works great for me.
99Runnr is offline   Reply With QuoteReply With Quote
Old 03-07-2016, 01:06 PM #5
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
YES! finally someone else that knows how to do it correctly!
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 03-07-2016, 01:40 PM #6
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough JayRolla will become famous soon enough
JayRolla's Avatar
That was the only way I thought it was done!
JayRolla is offline   Reply With QuoteReply With Quote
Old 03-07-2016, 01:58 PM #7
97Run-Man's Avatar
97Run-Man 97Run-Man is offline
Real Name: Miguel
97Run-Man is on a distinguished road
97Run-Man's Avatar
Real Name: Miguel
Can you explain this a little more? I have been trying to find out how the FSM says to do it.
I get doing the front and rear separately but do you bleed them with the car on and then again with the car off? How does that work? Thank you.
2001 Toyota 4Runner SR5 4X4
97Run-Man is offline   Reply With QuoteReply With Quote
Old 03-07-2016, 03:09 PM #8
97 _SR5 97 _SR5 is offline
97 _SR5 is on a distinguished road
I use a vacuum pump and always bled furthers to closest and haven't had issues
Rafal
1997 4Runner SR5 V6 Auto
97 _SR5 is offline   Reply With QuoteReply With Quote
Old 03-08-2016, 11:11 PM #9
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
I'm a little late but there is an important fact here that everybody in this thread is missing. The older systems like my '99 bleed the rear brakes first. If you don't bleed the rears first, you can't bleed the front. See this excerpt from my '99 paper FSM:
On the other hand, the later systems bleed the front brakes first, specifically front right, front left, then the rears. See this link to the 2002 FSM:
http://www.teamtoyota4x4.org/archivi...raflu/blee.pdf
[Edited to provide working link as of 4/18.]
Please stop thinking that what is right for YOUR truck is right for everybody's truck. I think 2000 is the last of the old system but that's a guess.
My Backyard Frame Swap
Old 03-08-2016, 11:37 PM #10
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
Thanks for the clarification durk
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 04-17-2020, 06:28 PM #11
2000Ltd4wd 2000Ltd4wd is offline
2000Ltd4wd is on a distinguished road
2000 LTD Brake booster?
Considering doing the tundra brake upgrade and obviously need to bleed the lines for that. Looking at this PDF from the FSM it talks about a hydraulic Brake booster that turns on when the ignition is on, but in my 2000 limited with ABS I only see what looks like a vacuum style brake booster and no sound is heard when ignition is turned in. Is it possible to bleed this ABS system without the scanner?
2000Ltd4wd is offline   Reply With QuoteReply With Quote
Old 04-17-2020, 07:09 PM #12
HiLife HiLife is offline
Kinda. If you don't have air bubbles in the abs pump.
If no air made it to the abs pump, you don't need a scanner to bleed the brakes.
However if air did make it to the abs pump you'll need the abs pump to cycle, and then bleed, that's when the scanner comes in.
Old 04-18-2020, 10:46 AM #13
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
We need to be careful with terminology here, specifically "ABS system" vs "ABS pump".
You do not need a scanner to bleed an ABS equipped brake system, because the ABS pump is isolated from the rest of the hydraulic system. So you bleed your brakes as discussed above, keeping in mind the different sequences for vacuum boosters on the older trucks vs hydraulic boosters on the newer trucks.
You only need a scanner if for some reason you need to bleed the actual ABS pump. So if you somehow got air into the ABS pump, like if you replaced the ABS pump with a dry unit, then you'll need to bleed the ABS pump. But not needed under any normal circumstances.
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 04-23-2020, 07:49 PM #14
Thanks for the reply, good clarification on the ABS and the different types of boosters. So I did the swap this week and everything seemed to go fine. However when I start the car the brake pedal drops near the floor.
I assumed air in the lines and bled again with no luck. Assumed blown seal on master cylinder and so replaced that, bled thoroughly and again no luck.
When the car is not started (ignition can be on) the brake pedal feels fully engaged a few inches in and feels normal, so I suspected maybe the booster, I disconnected the Vac hose from the booster and plugged it and drove the car around the block with manual braking. The braking was obviously slightly more difficult, but the pedal and brakes were engaging with much less travel. Re-hooked up the booster and same issue the pedal travels almost all the way to the floor before the brakes engage.
Considering getting a new booster, but due to the brakes being easier to apply with it connected I don't believe it is bad, unless the connection between pedal and MC in the booster is slipping? Running out of ideas here and by the "symptoms" listed here doesn't appear to be the booster. Any ideas before I throw in the towel and take it to a shop?
Thanks
Old 04-24-2020, 03:03 PM #15
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Thanks
Bleed the brakes one more time with the engine running. I know that is counter to what people say for 96-00 but it's the only way I could get my brakes to bleed on the 98 fully. Give it a shot.
Also, some years have a little one-way valve on the booster vacuum hosing that I think goes to the 4WD VSV. These little guys have been know to fail once in a while and cause bad pedal feel. Easy to check them, just take it out and blow in it, air should pass through one way and not the other.
326WHP 347TQ
Lift, Brake, LBJ Sequence? Kanger328 3rd gen T4Rs 12 01-04-2013 02:34 PM
Brake bleeding sequence? Presta24 Maintenance/Detailing 10 11-01-2012 07:54 AM
Brake Bleed DC Dude Maintenance/Detailing 18 08-29-2010 07:59 PM
Brake line bleed ksroqclimber 3rd gen T4Rs 3 08-09-2010 05:29 PM
Shouldnt any brake job also bleed the brake lines? Muti007 3rd gen T4Rs 10 04-23-2010 10:39 AM
