Originally Posted by UnderFire
always check compression before spending any money chasing a misfire on a RZ motor. I've seen broken valve springs, cracked heads, bad head gaskets and burnt exhaust valves
Thank you for that advice to check compression first where I would normally have done compression near the end of the process of replacing the plugs and wires as while the plugs are out, you routinely check the compression at that time just before putting the new plugs in.
This did happen suddenly, not gradually but I was coasting for a while before it happened, and I only noticed it when I accelerated onto a highway ramp.
I should have mentioned there were actually 2 DTC codes, P0300 & P0301, but that doesn't make sense that it would be multiple cylinders misfiring (P0300) if only one cylinder was misfiring (P0301).
The CEL was blinking which means it's more than one in 200 revolutions, so the catalyst was in danger of overheating (I only drove it 3 miles back home).
I looked up the compression spec for the 3RZFE which is 127psi to 178psi with the delta between any two cylinders not being greater than 14psi.
